Empty spaces on boards
  • keyboardcowboy
    • Apr 2006
    • 73
    Almost all boards have empty capacitor spaces,how can it be found that which cap should go there and is there any advantage in filling these spaces
  • Tom41
    • Oct 2005
    • 338
    • England
    Re: Empty spaces on boards
    These empty spaces usually result from the same basic board stencil being used for various different kinds of boards. Depending on what the board will be handling, it may or may not require caps in any given space.
    I doubt you would see any performance increase by putting caps into those spaces, on the contrary - it might draw so much power that the board becomes unstable!
    You know there's something wrong when you open your PC and it has vented Rubycons...
    • gonzo0815
      • Feb 2006
      • 1600
      Usually there is a version -in most cases a super deluxe one and very expensive wich is fully populated.
      So if you know something about the design, you can assume what should be there.
      Additionally, the VRM desing is mostly not designed by the board manufacturer, rather by the supplier of the VRM control chip.
      So you can google for the data sheet and the typical application.
      Then you can decide, if it is due to a component change e.g. some 3300uF caps instead of more 2200uF ones or if it is to reduce manufacturing cost.
      In the later case, may be it could be worth to add the missing caps.
      • MD Willington
        • Sep 2004
        • 702
        Engineering samples:
        We have some boards that are like that, we use them for development, while the customer gets a board that is only stuffed to the BOM for the final product.
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • gdement
          • Jan 2007
          • 690
          You can use a multimeter to see which caps it's in parallel with. You can also check the voltage on the pads while the board is running.
          I've populated some extra capacitors on a couple Asus P2B-F boards, and it did help them handle heavy loads a little better.
          • 999999999
            • Sep 2006
            • 774
            Sometimes a board is designed with more cap locations than caps to allow the manufacturer to use more than one kind of cap. If their supplier runs out or they find a better spot-price, they are covered and can use the alternate parts even if not of exact same spec.
            I have seen boards where cap locations unused, caused a problem. In particular I recall one MSI motherboard (unfortunately I forget the model #), which was a late PC133 or early DDR266 memory based chipset. The memory was stable but barely so at 133MHz memclock rate, but after adding caps to empty spots on the PCB, the otherwise unchanged system then overclocked by over 10MHz more. Funny thing was that I wasn't even interested in overclocking so much as I was playing around with it and checking stability margins and I'd found it alarming that it couldn't be o'c by much at all, before becoming instable with memory that had previously exhibited it was stable at higher speeds in another system. I'm not comfortable deploying a system that is barely stable even when brand new, I insist on it being stable at a little higher than the actual clockrates it will run at, too.
            Tom41 and gdement have good points. Checking voltage while it's running will give you a voltage range you need to meet, but you dont' want to indiscriminately add several thousands of uF capacitance which can result in a larger start-up current required from the PSU (which to an extreme level, could prevent the PSU from rising to running voltage fast enough), or that surge current through other parts can stress them unnecessarily. IOW, if/when I add caps to unused locations, I like to stick with a moderate to low value, not putting the biggest cap (highest uF) value in that would fit in the holes). If you've been studying other boards with similar designs you can get a better idea of what capacitance range seems reasonable.
            There's also the age-old saying, "If it ain't broke don't fix it". If you see no reason (no potential problem like caps overheating from current rise of overclocking) to add the caps, if it works fine as-is, it is not expected to be a worthwhile mod to do.
            • ugamazing
              by ugamazing
              12-17-2024, 07:05 PM
            • ugamazing
              Apple M1 Boards & Exclamatory Error?
              by ugamazing
              We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
              Has anyone else run into this...
              02-20-2025, 09:24 AM
            • ugamazing
              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
              by ugamazing
              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
              08-31-2022, 07:34 AM
            • hopkok
              Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
              by hopkok
              Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
              3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
              I checked for low resistance on coils, no low resistance.
              Anyone with same issue like me?
              Thanks for any help.
              05-24-2025, 04:21 AM
            • midnightg35x
              Panasonic TC-P65S2 SU or SD Boards Bad?
              by midnightg35x
              I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
              04-22-2019, 05:29 PM
