Medical Devices Service Manuals
  • Med-Tech
    • Jan 2024
    • 26
    Hallo, anybody know where to get service manuals for Medical devices (other than Franks hospital)? The problem I have is with a physiotherapy machine it shows nothing on the display and the green LED flickers.[
    Thanks in advance.
    • Jul 2011
    • 6039
    Is this device your own do you own it free and clear and can do whatever you want it if yes to this question it appears to be a power supply issue because the back light is not lighting up I would open it and see if you have voltage at the secondary side of the power supply more than likely it is a switching power supply and if so look at start up capacitors usually they are under 100uf and will be near the switching power regulator ic chip
    If you need help with it please post some pictures of the power supply board both front and back of the circuit board make sure that you can read the print on the circuit board or on the components
    • Med-Tech
      • Jan 2024
      • 26
ID:	3644464 The capacitors have been replaces by me, but that did not rectify the fault. Here are some photos...
      Click image for larger version  Name:	20250524_161307.jpg Views:	0 Size:	957.8 KB ID:	3644455 Click image for larger version  Name:	20250524_161349.jpg Views:	0 Size:	875.3 KB ID:	3644456 Click image for larger version  Name:	20250524_161356.jpg Views:	0 Size:	723.0 KB ID:	3644457 Click image for larger version  Name:	20250524_161342.jpg Views:	0 Size:	727.2 KB ID:	3644458 Click image for larger version  Name:	20250524_161353.jpg Views:	0 Size:	862.3 KB ID:	3644459 Click image for larger version  Name:	20250524_161331.jpg Views:	0 Size:	1.07 MB ID:	3644460
        • 31024
        looks like it uses an external psu
          • Jul 2011
          • 6039
          I would agree with you but I would check the voltage output of each regulator do you have input voltage and output voltage if not go to switching power supply or the transformer power supply which ever one it has do you have voltage on the output use an incandescent light bulb to verify that you have current and not just stray voltage from the power supply source
          • CapLeaker
            Leaking Member
            • 8158
            Reseat the square chips in the brown socket, would be my first thing to do. Looks to me like the PSU starts then turns off. Where is the PSU to this thing? Measure the voltage coming out of the PSU.
            • Med-Tech
              • Jan 2024
              • 26
              There is anther part to the machine (the body), which I will test tomorrow with the control panel, as it supplies the power and post the info here.. The control receives its power through the 25 pin serial connector on the back of the PCB. I have reseated the chips, ready to test tomorrow.
              • CapLeaker
                Leaking Member
                • 8158
                Yeah, makes more sense now, that this isn’t the complete machine, rather just a part of it. Check that incoming power to that unit somewhere near that transformer looking thing. These square chips in the brown socked wiggle themselves out after years of use and cold to hot cycles and usually snap back always back into place. In the computer world symptoms would be something like no POST, etc.
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                  BLUECHIP BUSINESSline Medical S3100 i5-9400 Specification for Upgrade or Repair
                  This specification for the BLUECHIP BUSINESSline Medical S3100 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline Medical S3100 boardview and BUSINESSline Medical S3100 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 02:20 PM
                  BLUECHIP BUSINESSline Medical T3300 i5-9400 Specification for Upgrade or Repair
                  This specification for the BLUECHIP BUSINESSline Medical T3300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline Medical T3300 boardview and BUSINESSline Medical T3300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                • Yanleb
                  Panasonic part number in service manuals
                  by Yanleb
                  In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                  This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                  For an example, look at the attached PDF.
                  Do you have a way to cross reference the Panasonic part number with the actual part number?
                  Thanks....
                  07-03-2023, 08:16 PM
                  Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                  This specification for the Acer Aspire A317-53-32Z4 + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-32Z4 + Extended Service Plans boardview and A317-53-32Z4 + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                  09-07-2024, 02:20 AM
