Battery Hookup new listing “Case 100x 3.3v 2200mah - 200x 18650 Lifepo4” for $100.00 + shipping
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8712
    It is no doubt rust, but not caused from water coming from inside the cell (because there is no water inside the cell unlike alkaline or lead acid batteries). Likely you also got a pack that had water intrusion but not as bad as the one I got. Capillary action can explain why the rust appears to show up around the heatshrink.
      • Jul 2011
      • 6070
      I would go long with this explanation if it was not using fish tape that is covering the tabbing ends on the crimp end of the batter cells and only one that is facing the same way and the fish tape is not easily removed to inspect each battery cell so I am still confused by this explanation
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8712
        The PSA did protect the side that was stuck to it looks, and capillary action accounts for much of the rest.
        Unfortunately I can't make any judgments on the chain of events but the batteries were probably water logged before packaging.
        Incidentally if it really was brown electrolyte versus just rusty water being sloshed around, that electrolyte would be a lithium salt and those are polar. Polar salts should readily dissolve in water like sodium chloride, unlike iron rust/iron hydroxide which is poorly water soluble (but more so if the liquid has low pH). If you have a water wet towel, lithium salts should readily dissolve, but if it requires acid then it's more likely iron rust.
          • Jul 2011
          • 6070
          If this is the case then there is a quality issue when they were processed if this is the case might explain why this only happening on certain battery cells so what is the solution for the ones that are showing these symptoms that is depicted in the picture above with pure water and then dry them fully or is a better solution for this issue
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8712
            So have you proven what the brown stuff is?
            Is it rust or some electrolyte residue?
            I venture it is rust from the tabbing or contacts oxidizing and washing away and luck of the draw that cell got the water.
              • Jul 2011
              • 6070
              How do I prove which one it is
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8712
                First use a water wet napkin or paper towel. if it's easy to remove, it's could be a lithium salt but I thought most lithium salts should be white colored as it's not a transition metal.
                Then use vinegar. If it's easy to remove with vinegar, then it's probably rust that came from the rusty tabbing.
                Lithium ion batteries use some sort of lithium salt as the electrolyte mixed with a VOC to make it liquid. A common li-ion electrolyte salt is LiPF6 which should be white and is water soluble. Again water is not used as the solvent inside lithium batteries because there are free lithium metal atoms around, so a VOC is used instead. That VOC dries off fast.
                  • Jul 2011
                  • 6070
                  I will try water first and then vinegar and see which one cleans the mess off of it
                    • Jul 2011
                    • 6070
                    Here is a picture of the battery cell that has the most signs of leakage with the plastic disk removed and the paper towel was dampened with water and it cleaned most of it off of the battery cell crimped end
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8712
                      Yep, looks like water intrusion because the case (steel) is rusted.
                      BTW when I say "easy to remove" I mean it doesn't need scrubbing, just like when one wipes up table salt or sugar, the crystals just "melt" into the paper. TBH I don't use vinegar to remove rust, I use hydrochloric acid and iron oxide rust likewise dissolves into the acid/paper into a liquid (though this is a chemical change instead of a physical change - the iron oxide (only slightly soluble to insoluble) will react into iron(III) chloride which is soluble.)
                        • Jul 2011
                        • 6070
                        This might be the case IF these battery packs were used in air conditioned computer because I know for a fact that they keep these rooms extremely cold I understand why but if the environment where these battery packs are stored is extremely cold would explain this but why only some of them are showing symptoms like this
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8712
                          Remember you aren't the first owner, these things have been around for 4 years before you got them!
                          Also keep in mind that the period where they were removed from service, and put into BH's warehouse, it may well have been outside for a while and it still could have been luck of the draw which packs were outside, on the bottom, underneath a roof overhang during rain, etc., etc.
                          The corrosion you saw with that pack is worse than the corrosion i saw with the second pack I opened... but clearly a LOT less than that first one!
                          Click image for larger version  Name:	corrode.jpg Views:	0 Size:	187.2 KB ID:	3651397
                          P.S. I hate my camera phone, oh gawd this photo is so much better than what I can do with my stupid camera phone...sigh.
                            • Jul 2011
                            • 6070
                            From that picture perspective I would agree with you that it might have been in water at one point in time but I just not use to seeing bright orange rust I am use to seeing a more brownish orange color
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8712
                              Given a thin enough coating, rust will indeed appear orange, though it is still dependent on how it reacted with the iron. If allowed to sit for a long time yes probably will get more brown rust but if agitated you'll get orange rust. Not sure if you saw a fresh rust spot on cars with paint damage, it's always orange-ish... I suppose the galvanization has a role though.
                                • Jul 2011
                                • 6070
                                Stay tuned more to come on this topic right now I am doing some testing on a boost converter that I also have a post about that I just updated today
                                  • Jul 2011
                                  • 6070
                                  Limited Stock: 25.6V 6Ah LiFePO4 Batteries with BMS – Only 100 Cases Left!
                                  12:23 PM
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8712
                                    no $, space, or applications yet for more
                                      • Jul 2011
                                      • 6070
                                      I do not know why Battery Hookup thinks that these 24 volt battery packs are worth $30.00 more than what they cost now because now they are not a good price anymore
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8712
                                        yeah i don't know why they decided to jack the price. Perhaps losses on the bad packs? If they didn't write that they were all good then maybe it wouldn't be an issue...
                                        But maybe demand went up?
                                        hmm...still tempted to get more batteries. I wonder if I should try to re-cell my eeePC's battery pack (2S3P 18650) though without a tab welder...
                                          • Jul 2011
                                          • 6070
                                          You could do it without a tab welder but you would need a high powered soldering gun but you would need to wrap the battery cell in water logged rag that is somewhat rug out to keep the battery cell from getting to hot but would drill holes in the tabbing so that you have more contact surface for better joint strength not so much for the positive side of battery cell but for the negative side but do not put the wet rag to close to the battery cell where you are soldering because it would require way too much heat and would not give you a good joint but yes it could be done but make sure that you use flux and good quality solder for best performance
                                          But it would be better to use pure nickel tabbing or copper strand wire that looks like soldering wick but if use this I would recommend that use heat shrink tubing between the battery cells especially on the positive end of the battery ends
