Battery Hookup new listing “Case 100x 3.3v 2200mah - 200x 18650 Lifepo4” for $100.00 + shipping
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8713
    Dang these 24V packs are too big to squeeze two into my scooter as-is.
    Looks like I'll have to rip out the foam to make them fit, or jury rig some other way to squeeze these packs into the battery chamber.
    Originally it uses two standard 12V 7Ah packs. A single one of these LiFePO4 packs is 6Ah already has the same or effectively more available energy than the lead acid due to discharge rate. Didn't try riding it but just one seems to spin the motor fairly well. However, I suspect with a ⅓HP motor, it'd need to run 10-15A and up against the BMS limit which is probably not good. I suspect with two, the total of 12Ah it probably would get near 3X the original design distance?
    The only thing that definitely would be nice is to carry a high speed charger ... not the one that comes with the scooter that takse overnight to charge.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8713
      hmm... the scooter charger measures 28.1V OCV and is 1.5A., it may be good enough to charge LiFePO4's...
      Seems to light two 1A 12V lamps in series, but it gives out on two 2.2A 12V lamps in series.
      Testing with the LiFePO4 it only charged 1A...which is a bit low unfortunately...
        • Jul 2011
        • 6070
        This is probably normal that if your load is one amp it lights normally but when you try two then it is dose not want to light which is exactly what you want in a battery charging controller
        Here is why lets say that you have an issue with a battery pack and you use a switching supply that does not limit charging current this way then and only over current for the switching power supply then it would just keep resetting it and not lock out like a charging controller would
        Yes it is a lot slower ithan a switching power supply that has a maximum current capacity and if reaches the maximum it should just stay in the off position until you power cycle or remove the battery pack from the switching power supply
        I will have to charge one of these battery packs to 28.1 volts and see how much of a charge it really has by putting back on and changing the cutoff voltage to 29.5 volts and see how many milliamperes difference there if there not much difference between the two voltage settings might not make that much difference in running time
        Question I have is how many amp charging do you want for fast charging me personally I would not go more than 5 amps maximum but I would not necessarily want to fast charge all time because it dose over time degradation happens to the battery cells just look at long battery operated tool battery packs last if run them down to no power and recharge them in fast mode all the time I susceptible this is what get battery cells to the end of life sin drum and self discharge and at this point the battery cell is not very useful unless you charge it and use it then
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8713
          I thought it would be just current limiting, but it appears it detects a shorted battery and says it wants nothing of it, shutting down. Fair enough.
          Well, this psu is a SMPS so perhaps I can tweak it to get higher voltage, but the amount of power it provides leaves much to be desired. 5A sounds good! Well if I do squeeze two packs in the space allotted, that wound mean i want 10A to be a bit under 1C. A bit over an hour to charge 20 miles (or probably more)... That's faster than walking!
          Next is to figure out what connector I should standardize on...need a cheap connector...
          I have a few XT90s and EC5's but XT60 is probably more appropriate. Or Anderson powerpoles? Faston just to be compatible with Pb-H2SO4?
          Alligator clips are not a long term solution...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8713
            Hmm... I am a cheapskate. Guess what I'm doing...
              • Jul 2011
              • 6070
              You are reusing the connector pins from the battery pack but how are you going to use the pins in what connector
              How hard is it to get them out of the connector housing
              I have not tried to take any out yet I just been cutting off at the connector housing
              Did you get your replacement 24 volt battery pack yet from BH or are you still waiting for it come in the mail
                • Jul 2011
                • 6070
                Well my solar panels showed yesterday at the front door wow they are huge unfortunately the connectors cable will come next week but I have some short ones that I can use to do some testing over the weekend
                They are over 4 feet long and probably 2 or 3 feet wide and has one of the nicest frames I ever seen on a solar panel I ordered 4 of them for the price of two of them at regular price
                I have to figure out how I am going to mount it on my shed's roof on the studs and also keep it from leaking water where the bolts going into the studs
                Now I have to figure out what configuration I should and need to use for charging battery packs this part of this project I have not figured out how to do this the most efficient way to not destroy the solar MPPT charging controller by changing from one battery pack to another battery pack
                Although I do have a related question is possible to use two MPPT charging controllers on one set of solar panels or is this a NO — NO and should not be considered or done this way
                Or is there a way to simulate a battery pack when changing from one battery pack to another battery pack or do I have built a relay logic system controller for switching from one battery pack to another battery pack to switch off the solar panel from the MPPPT controller then switch battery packs then reconnect the MPPT controller again still have incorporated a timer system because of chatting the relay contacts connections I do not need to have much time between turning off the charging controller and connecting the next battery pack
                I plenty of different relay types that I could use for to make timer modules controller but I do not have or timer ic chip or timer module
                One problem that I have about charging my battery pack on solar panels is if I use the MPPT charging controller I can only do 12 volt or 24 or 36 or 48 volt battery packs according to the manufacturer description of this controller
                I want to be able to charge battery in between these various values so what is the best solution for this problem
                Or could I use a buck converter for this purpose but do I have to use a load resistor to keep the solar panel voltage to stay at a certain constant voltage for the buck converter which I quite few of them and several that have the voltage current meter module on them
                I want to use my lower power solar panels for this type of pro type and proof of concept because the current limit is about 2 amps which for testing purposes I do not need any more than that
                On a similar note on high current solar panels like 100 watt ones is safe to a short circuit test to see what amp output they have or should this be avoided at all cost and just take what the manufacturer has in there description for these solar panels
                Now I also have several 5 or 6 volt solar panels at one amp current output I going to make a solar powered charger battery pack for my iPad for using outside there is nothing special about using these solar panels other than using a blocking diode for the solar panel to the battery pack cells ( I know that this is doable because I have already tested this in a proof of concept a few years ago but just never really made one that is actually made for this purpose )
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8713
                  The self-incompatible hermaphroditic connectors appear to piecewise self-mate, the male pins are not too useful (since they are used for the temperature sensor) but the female pins mate with the output and that's what I'm reusing. Of course the wires are way too narrow, probably will have to solder new wires to the pins. The housing seems to fit the holes in reverse too, if I cut off the keys. Going to chop the connector and just use the pieces for the main pack wiring.
                  I got the replacement from BH so I guess that's resolved.
                  BTW MC4 connectors mate with banana plugs so if you have some certain banana plug connectors you can get started right away. I have some alligator clips that accept banana plugs and they fit MC4 male connectors just fine, turns the MC4 male into a ... alligator clip.
                  Using two charge controllers on the same panel set is probably not a good idea due to isolation problems...
                  Yes solar panels can take shorts just fine at least for short periods (and an hour is "short" though unsure of long term). The MC4 connectors may not however, they were not designed to be welding sticks.
                  Oh and no, I'm not going to use MC4 connectors on the batteries...
                  Update: looks like the recovered 12V pack I made from the damaged 24V pack is not very good. The one cell that I found that was low voltage is leaking energy. After recharging I was about to get about 50 minutes of 4 amperes load, but today I saw that there was pretty large unbalance:
                  3.03V
                  3.29V
                  3.29V
                  3.29V
                  hmm... it seems to have done something at 2.4V!
                    • Jul 2011
                    • 6070
                    To what voltage did you charge it to and at what current level were you using while charging and long did you let it charge for
                    Also the battery cell that is low on voltage charge this by itself and see after it gets close to 3.7 volts does the battery get warm if so then your hunch would be correct
                    All I am after is dose the solar panels put out 8 amp like the description says is what I want to know about
                    That would be straight if something happened when you discharged to 2.4 volts I gone down to 2.0 volts before and nothing weird happened doing that so I do not know what to tell you about that
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8713
                      I got all of them to ~3.6V or possibly higher by individually charging cells and let it rest overnight, they were balanced then (all around 3.37ish volts) and then the 4 amp 50min discharge, and then another overnight rest period before testing. Then when I saw the 3.03V I put a load on all the cells and the BMS seems to be alive and cut off power when that weak cell hit 2.4V.
                      I think most of my proper solar panels do get pretty close to Isc only when it's cold outside. It still gets reasonably close when it's warm however. Only exception is when I got a false advertisement panel and it didn't get anywhere close.
                        • Jul 2011
                        • 6070
                        What I would do then just remove that battery cell from the battery pack and just use it as a 9.6 battery pack and be done with it
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8713
                          Yeah that would be good, just that I don't have any use for a 9.6V pack...
                            • Jul 2011
                            • 6070
                            What about powering a multi meter that uses a 9 volt battery cell or use them to charge your cell phone or tablet
                            But on a slightly different question I had a brain storm idea maybe not a good one but I would like to know if this could be used to simulate a battery pack
                            using six of these in series to change from one battery pack to another one something like this
                            https://theelectronicgoldmine.com/co...roducts/g28917
                            Not this version but one smaller to this type of capacitor that are used in a battery tabbing welder
                            A while back I bought a bunch of these when they were on sale half price and right now they are just sitting in a container just waiting for some project to use them in
                            Of course I would charge them up to 15 volts first then put it on the MPPT charging controller or whatever the pack voltage is
                            Do you think this would be doable or would I destroy the MPPT controller by doing this
                            In the name of science waste $40.00 for a proof of concept idea
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8713
                              Too big and still need voltage conversion... and this bad cell still holds energy, just leaks. I still have a few Li-Mn/Co cells around that could be used for phone charging... just that these are 4S or 3S and neither of these are good for 12V.
                              I don't think it's a big issue if you connect battery first, then solar, then disconnect battery. You could connect a small battery in parallel to keep the MPPT controller running but it should, except if half way in between having the battery disconnected an airplane flies overhead and shadows all your panels...
                              Not sure what's the issue with battery disconnection, you could also work on it at night? Have a solar panel cutoff switch??
                                • Jul 2011
                                • 6070
                                I think the reason for this particular parameter is that it has automatically detection of what battery voltage you are using question is when you remove the battery pack does it remember the size of the battery pack or does it search for what size battery pack you have hooked up even though you do not have one there and what happens when you plug a battery pack to it this way
                                Now I looked at the PWM type solar charging controller dose not have this warning about having the battery hooked up first so maybe I should just use this type and be done with this issue
                                Now using a solar cut off switch might be a good option and idea I going to give this some serious consideration as a possibility for a simple solution to this problem
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8713
                                  It might be easier for you if max current / Isc is less than 10 amps. For me, I have in excess of 20A flowing at times, and DC cutoff switches start to get spendy... fortunately my mppt is a gti so it always has grid power when needed...
                                    • Jul 2011
                                    • 6070
                                    I have a question for you about GTI that have an option to use no battery pack power is that a good option it says that it it has a MPPT controller in it
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8713
                                      GTIs should have MPPT built in, it doesn't really make much sense otherwise. However mine does not have battery pack option and I've been jury rigging a battery pack to it for fun.
                                        • Jul 2011
                                        • 6070
                                        Which one is better one with a battery pack or one with out a battery pack what is different about them and does it matter which one you choose
                                        And how did you jury rigging a battery pack to it in the first place and is that a good option in the long run
                                        Would this one be a good choice
                                        https://www.ebay.com/itm/32631398408...2GGXS5KDQV3FKT
                                        or would an off grid pure sign wave inverter be better for what I want to do
                                        https://www.ebay.com/itm/20496403792...BlBMUPSKzILgZQ
                                        With my MPPT charging controller work better because I want to do some of this off grid stuff
                                        In case of utility power outages is concerned that is what I am really interested in more right now
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8713
                                          Of course if it has battery pack capability it's better. I didn't have a choice, I got the broken one for free. If you want plug and play definitely get the one with it integrated.
                                          GTIs should be pure sine to match the grid sinewave...
                                          I don't know what your focus is. Mine was to offset grid power costs, I have grid power. I have batteries to store energy and eventually want to just run offgrid if needed, but that's a different project. For running when the grid is down, I have a whole bunch of regular inverters (300W, 350W, 400W, 2500W) but need 12V to run them...
                                          Annoyingly my 400W inverter with a 35Ah lead acid battery was insufficient to start my refrigerator (due to inrush), and my 900W genset also didn't like it (probably due to same). I will need to try a bunch of 12V LiFePO4's ready to see what it can do with the 2500W...
