Hi everyone, I bought a QFP64 adapter for RT809h, but I haven't figured out how to read and reprogram yet. I can't find the microprocessor in the list. How do you read this? Thank you
Qfp64 for RT809h
Well, personally, I use the Easy-NAND Tiny Tools V2.1 programmer. You can read and program without soldering in single-wire mode (VDD, GND, RESET, MODE), a total of four wires need to be soldered, usually these contacts are located on the board.Comment
You can buy it here, but is it really possible now? Renesas has its own programmers (Renesas E8A, Renesas E1, Renesas E2, E2 lite), and also supports BeeProg, BeeProg+, BeeProg2 programmers, but they are all expensive.
Easy-NAND Tiny Tools V2 - https://www.ejtag.ru
Also supported by UFPI programmer - https://mslw.com/product-category/ufpi/Last edited by lotas; 10-29-2024, 06:24 PM.Comment
by tbsmithI'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
by NitroX5Dear Community,
I would need help for the following case:
Lenovo Legion Y530-15ICH - 81FV
BOARD#: EY515/EY517/EY519/EY520 NM-B701 REV: 1.0 2018-03-21
Problem: device went off during office work. (no hard game playings before). No LEDs, no charging, nothing. Analisys showed the IT8226 SIO 3.3v is shorted, therefore I oredered a pre-programmed one from a reputative seller electronicloop.
After replacement 3.3v got available but I still have no LEDs, no charging circuit voltage...nothing.
The EC soldering verified dozen of times -no moving or shorted...1 Photo -
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
by Deby
This is a list of compatible laptop motherboard information that I have been collecting for some time.
And it's still ongoing.
Every time I come across information that a board is compatible with another, I write it down.
Anyone who wants to, can continue to expand the list.
Packed in the rar, is an excel table that has additional information.
Motherboards.rar...05-31-2024, 04:34 AM -
by sassanhello,
i want to buy a new programmer mainly for use for laptops bios chips and i'm between the Xgecu T76 and the famous RT809H.
i think that T76 is faster wich makes it the best choice for using Pogo pins,i asked the support if it supports Mec ships found on some Lenovo laptops i didn't get an answer yet.
i would like some ideas and which one do you recommend?... - Loading...
