Low Voltage Going To Regulator Input Pin
  • Grannyrogers
    • Mar 2014
    • 14
    • United states
    Good day all,
    I have a tv logic board that has 1.69v going to all regulators except one when the correct voltage should be 5v. The board is receiving the correct voltages from the power supply, which are 5v and 15v respectively, so my question is: what would cause several regulators to receive low voltages? Could it be bad caps?
  • Grannyrogers
    • Mar 2014
    • 14
    • United states
    Re: Low Voltage Going To Regulator Input Pin
    Does anyone have any idea?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8707
      without the device itself in hand, a schematic or even a picture of the device it's hard to tell...of course it's possible, or it could be multiple failure caused by bad caps...
      • Longbow
        • Jun 2011
        • 623
        If the logic board itself has +5v, and the input to all regulators is +1.7v....then obviously you have a high resistance somewhere between the input plug and the regulators. Turn the power off, pull the power connector to the logic board. Measure the resistance from the +5 terminal to the input of your regulators. Then follow the power traces back to the power connector.
        Is it plugged in?
        • artvandalai
          Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
          by artvandalai
          This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
          The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
          11-05-2024, 07:38 AM
        • shakib200
          Ram regulator misbehaving DDR3 VTT voltage Tps 51216
          by shakib200
          The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
          Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
          03-16-2024, 11:33 AM
        • slothen92
          Volvo HU850 Radio/CD-player repair, LDO-voltage regulator IC
          by slothen92
          Hello
          Im trying to repair the Volvo HU850 radio/CD-player from a Volvo V70.
          I have ordered replacements for the four transistors (SD1760), but Im not sure about a replacement for the low dropout voltage regulator IC (marked by the red circle in the attached picture).
          On the body of the IC it says: “LF33AH GK133544”.
          Does anyone know where to find this part or a replacement for it?
          Cheers
          04-09-2025, 08:30 AM
          ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
          Optimized Multi-Phase PWM Controller
          with 6-Bit DAC for VR10.X Application
          The ISL6556A controls microprocessor core voltage
          regulation by driving up to 4 synchronous-rectified buck
          channels in parallel. Multi-phase buck converter architecture
          uses interleaved timing to multiply channel ripple frequency
          and reduce input and output ripple currents. Lower ripple
          results in fewer components, lower component cost, reduced
          power dissipation, and smaller implementation...
          11-05-2024, 03:10 PM
          Richtek RT8205L RT8205M Power Supply Controller for Laptop Computer
          The RT8205L RT8205M is a dual step-down, switch mode power supply controller generating logic-supply voltages in battery powered systems. It includes two Pulse-Width Modulation (PWM) controllers adjustable from 2V to 5.5V, and also features fixed 5V/3.3V linear regulators. Each linear regulator provides up to 100mA output current with automatic linear regulator bootstrapping to the PWM outputs. An optional external charge pump can be monitored through SECFB (RT8205M). The RT8205L/M includes on-board power up sequencing, a power good output, internal soft-start, and internal soft-discharge output...
          10-23-2024, 03:58 AM
