Temperature controlled Led build
  • Tekno
    • Oct 2013
    • 18
    Being familiar with the cathode tube and leds that feature the music reactive feature i was wondering if this can be similarly achieved with temperature. For example if i had 3 or 4 strips of leds red, orange, yellow, blue.
    At start orange would be on, when temperature reaches say 120c red would come on as well, 150 yellow and 200c blue.
    I assume a thermocouple would be needed to gauge temperature but beyond that i am unsure as to how to acheive this.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Temperature controlled Led build
    There are many ways to do this of course...
    You'll need to get accurate resistors and a good voltage reference, and multiple op-amps. First you'll need an op amp stage for voltage gain as thermocouples do not generate that many volts, depending on what thermocouple you have you'll try to get enough gain to cover as much of the output swing of the op amp (and worry about noise...). Then you'll need several comparator stages which can be built with op amps or comparators. The comparators have the reference voltages set with the resistor dividers that match the voltages you get from the first stage. This is a "flash" ADC topology just like a lot of the digital VU meters. An LM3914 all-in-one flash ADC could be used too, similar to other designs...
    I think the first stage, dealing with the thermocouple (or if you don't have to go very high, say 100C is enough a thermistor is somewhat easier to work with as it will have a higher voltage swing) is the trick. At least thermocouples are fairly linear unlike thermistor voltage dividers which have a very strange temperature to voltage output relation - which is not a big deal if you made your own turn on reference voltages...
    Hope this is a good start on figuring out how to do such...
    • Agent24
      I see dead caps
      • Oct 2007
      • 4974
      • New Zealand
      https://www.sparkfun.com/products/306 could be quite useful
      -David VanHorn
      • clearchris
        • Dec 2013
        • 687
        Arduino + maxim type k to serial output chip is how Id do it.
        • mariushm
          • May 2011
          • 3799
          If you want to stick to below about 125c, you can use very cheap integrated temperature sensors such as MCP9700, which tell you the temperature with about +/- 2c accuracy by outputting a certain voltage for a specific temperature.
          You can then adjust that voltage using an opamp or read the voltage into a microcontroller and do something with the information.
          MCP9700: http://uk.farnell.com/microchip/mcp9...-92/dp/1332166
          For higher temperatures, there are ICs like the one Agent24 mentions which are basically reading the K probe and have a built in correction table (output of a K probe is not linear from -something C to +something C, it has to be adjusted from place to place). The chip also allows you to adjust output to some specific voltage range (for example 2v for 0c and 5v for 500c or something like that).
          The downside is that it's very expensive but at the same time it's very accurate. Sparkfun's price is actually quite reasonable for that IC.
          There are other ICs that are cheaper but don't have the same precision or accuracy or are designed for other temperature probes which may not work at as high temperatures as the K probe. Lots of sensors and chips to explore here: http://uk.farnell.com/sensors_temperature
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • alexjt
            Help: Precise temperature controlled solering station
            by alexjt
            I'm a watchmaker/clockmaker who's looking to buy a soldering station that will allow me to blue my steel parts.
            The idea is that I polish my part and clean it then use the soldering station set to 274°C to give a perfect blue.
            I've been looking at loads of different models, Weller, ETC. But haven't found something I'm sure on, as everyone has their own marketing etc.
            I need something that I can take the tip out of a soldering iron, put in a brass plate that will heat up, I then put my part on the plate and it will turn blue because of the...
            02-02-2020, 09:03 AM
            Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
            When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
            This switching power supply was really fun to recap the quality of the board was very good...
            02-25-2024, 08:55 PM
          • asdas09
            Temperature to remove chips from motherboard
            by asdas09
            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
            I have device Sugon 202. I'm used also normal flux and rosin flux.
            09-12-2023, 12:44 AM
          • Dreigas
            ISL95880HRTZ desoldering temperature
            by Dreigas
            I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
            Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
            09-13-2024, 10:59 PM
