triac phase control 0-100%
    • Jul 2011
    • 6070
    Actually I need something that you can control the inrush current for a short period of time ideally that can handle 100 amp or more would be ideal
    The duration time can be controlled by a a microcontroller the monitoring the zero-point of the wave form also can be controlled by a microcontroller but to get them to work together is a another story
    The ones that are available have a couple of short coming one of them is that they limited to the amount of milseconds they can be adjusted to the other short coming is that you are limited the current output because in most cases the battery spot weld looks like crap because it either did not penetrate the metal on the battery terminals or the spot weld does not penetrate the battery terminals or the tabbing metal I want it to the point that it tears a small hole in the battery terminals or that it tears the tabbing but it literally leaves the tabbing material on the battery terminals so I back down the current a little bit to avoid that situation from happening
    Yea I know that that I might be asking for a prefect world but I want to get as close as possible to a prefect world as I can
    Yes you can get a modified micro wave oven transformer to get the battery tabbing hot enough for the tabbing to stick to the battery terminals but it has to stay on for at least a second for this to happen and the battery cell does heat up a little bit so this not a real good solution and for a battery welding transformer is ideal because getting it to work on a timer like you can on a microwave oven transformer is not as simple now you can with a transformer controller that does not have the timer function and you set it so that it does not trip the breaker but usually this hot enough for a good tabbing results
    So now the question is where do I find a breaker that is a “slower breaker to ignore the inrush current.” what is the search requirement to find this type of breaker
    I found this breaker from ABB “K type of breaker”
    https://www.ebay.com/itm/12610216461...Bk9SR9ys69qPZA
    I did some research and found several types of breaker types “A , B , C , D and K” type K has the longest trip delay for inrush current I going to buy a couple and try them on the welder transformer and see if this makes a difference in weather or not I run on my transformer controller at nearly full on or not because before I could not do that
    I know that I going to have to dedicate an outlet for this particular purpose from my electrical panel in my shed for this
    This should not be a problem because I ran #6 wire cables from the house to my shed and have 60 amp breaker in the house main panel for this sub breaker panel for the shed
    For this special outlet I going to use #6 cable for these two outlets for the battery stud welder transformer
    The transformer controller and for the special timer that I found that does milliseconds and seconds formats it also can repeat cycles for a certain amount of times as well
    So the wiring will not be fire issue the only smaller wiring will be to the breaker and the outlets because a #6 wire probably will not be able to be connected to them realistically and might to difficult to attain
    I do not like to cut strands off of a cable wire to make it fit in properly on a connector I try to avoid this at all cost if I can
    Realistically #6 cables can handle 55 to 65 amp loads depending on how long your run is it is about 100 feet run
    But seeing that this load would be for a certain amount of time and not continuous load I should be able to push the current limit a little bit for short durations with out any issues
    For a while I had a battery spot welder controller that worked very well for a while doing spot welding but eventually the controller went bad but when it was working it would dim the light in the house each time I would trigger it to weld my wife would ask me what I was doing to make the lights dim like that I would say that I was doing battery tab welding
    The only way to get this type of controller I would have to buy another battery stud welder that has this specific controller that actually works really well but it only lasts for a year or so for the amount of battery cells that I have been doing but my plans are to more of them than what I have done in the past so I need come up with something that works as good and last a lot longer than what I have been using
      • Jul 2011
      • 6070
      I plan on doing more battery cells than what I have done in the past and I need to come up with a solution for not getting the best tabbing results that I am looking for
      At this point in time I doing this to do a proof of concept test to see if it is possible to do it this way and not keep tripping the breaker doing it and to make sure that the wiring does not exceed 100*F while doing this I have a thermo imaging gun that I going to be using to for this test as well
      One note I going to have the air conditioner on one leg and the battery stud welder on the other leg so I am not over loading one leg and trip the breaker in the electrical panel in the house for the shed so far I have not tripped this breaker doing battery welding I have only tripped the breaker for the circuit for the battery stud welder outlet
        • Jul 2011
        • 6070
        Originally posted by stj
        i dont think a power controller will help a welder,
        you need that current-spike for the welds.
        It probably will not help with this application but I have another project idea that it might help which when I have time to experiment with the idea I will post the results of what I find useful
        • harp
          • Jun 2022
          • 648
          • Planet Earth
          Not based on triac, but also interesting circuit to lower AC voltage...
          https://m.youtube.com/watch?v=_HfknbJRo5I
          • redwire
            • Dec 2010
            • 3912
            Well, that circuit makes a lot of heat dropping the voltage down. It's a series-pass design using a power transistor+bridge rectifier to do linear control. Need a big heatsink.
            • harp
              • Jun 2022
              • 648
              • Planet Earth
              #26
              Here is a circuit that implements phase-control of heaters, adjusting their power smoothly from zero to around 95% of the rated power
              https://ludens.cl/Electron/thermost/thermost.html
              • redwire
                • Dec 2010
                • 3912
                That looks neat, the two transistors make the circuit sensitive, it does not require much current to activate the triac.
                But... what is the difference between say 25% and 75% power? Is it 1 or 2 or 3 degrees etc. Depends a lot on the thermistor curve.
                  • Jul 2011
                  • 6070
                  Very interesting circuit design
                  • прямо
                    TRIAC circuit
                    by прямо
                    Anyone is familiar with a TRIAC circuit?
                    I came across this schematic, and I built it, but I can't seem to figure it out why I'm getting a low AC voltage output at the TRIAC terminals.
                    With 230V AC hot side at the TRIAC MT2, I measured 60V AC between MT1 and neutral side when the comparator output LED indicator is on, and 20V AC when it is off.
                    Same result if 230V AC hot side is at MT1, and I measured between MT2 and neutral side.
                    My heating element doesn't work with 60V AC. It's not even getting hot and the thermocouple amplifier output is a...
                    04-27-2024, 02:12 AM
                  • vincentedel
                    Samsung SyncMaster 740n Phase Control Issue
                    by vincentedel
                    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                    04-22-2025, 12:33 AM
                    1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                    I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                    This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                    12-29-2024, 07:18 AM
                  • Astonished
                    Fixing the Charge Circuit of the Batteries of the DC Motor
                    by Astonished
                    Hi friends of electronics
                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                    Please help me fix this circuit.
                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                    01-28-2025, 06:24 AM
                  • privato89
                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                    by privato89
                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                    Let's begin:
                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                    03-26-2024, 06:37 AM
