need very quick advice time sensitive
  • Bigzo66
    • Jan 2014
    • 14
    found an ad on craigslist for an 70" sharp led tv model# lc70c7500u for $1300.
    I called the guy who seemed older about mid 50's and he sounded legit. he said I can come to his house test the tv as much as I want even watch a few shows to ensure that there's no issues with the tv cutting off. by the end of the convo he said he will take $1,000 he said he has a family hit some hard times and needed to sell. tv is top of the line sharp with 240hz quattron 3D all the bells and whistles. he also said he wanted me to meet at his home instead of a public place just to show that its legit. im going there today at 3pm
    is it a good buy tv still sells new for $2,100
    and what should I look for any tips/pointers before buying the tv
  • flat-earther
    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
    by flat-earther
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in...
    06-08-2025, 02:00 AM
  • Gwynz
    First time recapping a motherboard, need advice!
    by Gwynz
    Hey guys, I just picked up an old Athlon motherboard (Chaintech 7AJA2) to build a vintage PC system around and noticed it had a leaking cap and a few others that appear to be bulging
    It does boot up fine though, just finished installing Windows XP and it ran through a few 3dfx demos successfully (using a Voodoo3 3000 AGP card) but it does seem to have issues when I have more than one stick of RAM installed, should I also change out the little squat capacitors that are around the DIMM slots even though they appear fine?
    04-04-2022, 11:44 PM
  • OscarAV
    HP Pavilion dm4-1065dx long time to get the power led on
    by OscarAV
    I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
    I have made a quick search for my laptop but I have not seen anything similar.
    I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
    09-23-2024, 05:53 PM
  • dougg3
    Intel DX58SO high side VRM MOSFET keeps failing
    by dougg3
    Hi there,
    I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
    • 6 x High side MOSFET: NTMFS4841NH
    • 6 x Low side MOSFET: NTMFS4834N
    • 6 x Driver: ADP3121JCPZ
    It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
    10-17-2021, 07:39 PM
  • disorder
    LA-7092p (packard bell P5WS6), some advice before wasting time
    by disorder
    hello guys,
    need some advice
    have to repair a PB laptop, with la-7092p motherboard
    at start : no led, no power, totaly dead
    19v not present after 1st mosfet, short to ground. found upper mosfet on +1.5V that was short (between 19v and 1.5V), lower mosfet between +1.5 and ground is ok
    RAMS are dead too i think : after changed mosfet, short remove without rams and reappears when rams plug in. if i put a new ram, no short at all.
    if i remove rams : i have 19v , 3.3v , 5v but no +1.5v and no 0.75v (that's normal i think cause it cames...
    01-17-2020, 09:12 AM
