Tantrum -I mean, Tantalum caps...
  • Maxxarcade
    • Jul 2006
    • 973
    I've been replacing handfulls of leaky tantalum caps on Jukebox amps at work lately. I thought these were supposed to be reliable? They were causing random static and popping in the audio, even when no input signal was present.
    In went a pile of Panny FC's and Chemicon KY's to replace them, and now the clarity is better than a new amp, and no more static.
    About 20 of them were 1uf, 25v parts, some 10uf, and a couple 4.7uf. I used all 50v rated caps since that's what I had, and they fit perfect.
    Most of the 1uf caps had ESR of about 8 ohms. The replacements were around 2 ohms.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Tantrum -I mean, Tantalum caps...
    Well, tantalums last longer than may be elektrolytics, but it is very common, that they literally disolve after some time or they go open.
    Especially, if the appliacne was not in use for a few years, tants may explode after first power on.
    Manufacturers have since then improved the tants to a degree, but any way, they don´t last forever.
    May be KC8 can tell you more abouth tants, as he fore shure has a little more experience with them.
    • capamatic
      • Apr 2006
      • 33
      What equipment did you use to test the tantalums ?
      • Maxxarcade
        • Jul 2006
        • 973
        My EDS Capanalyzer 88A. Probably one of my most used tools. Though I need to send it out to have the test leads updated to the better type. Mine has the flimsy Pomona tweezers.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
