How the boards communicate?
  • Ashroyer05
    • Sep 2013
    • 162
    • U.S
    I am a recent grad in electronics so I have a lot of theory and some hands on. Since I have started fixing tv`s (and in some cases attempting) I am curious in how the circuits communicate and in what sequence. The power supply is in standby when plugged in then the main board tells the psu to activate a higher voltage? Is that correct and what happens after?
  • Ashroyer05
    • Sep 2013
    • 162
    • U.S
    Re: How the boards communicate?
    More precisely I'm curious in the signals between the boards. If a psu goes high voltage is the signal from the main a constant high for that duration or does the signal go low and then high again when the main wants the psu to reduce voltage back to standby voltage?
      The signals from the main board to the power supply board and to the inverter boards are usually active HI, it is steady state, usually the HI can be from 2~5V, <1 = LO. Some manufacturers may use active LO. Read the basic troubleshooting guide below.
      • cheapie
        null
        • Jul 2010
        • 849
        In computers, the power supply starts out only supplying only the 5 volt standby (purple wire). When the power button is pressed, the motherboard connects PS_ON (green wire) to ground. This causes 12V (yellow), 5V (red), 3.3V (orange), -12V (blue), and "Power Good" (gray) to come on. When the computer wants to shut down, PS_ON is disconnected from ground, which causes the power supply to switch back to only supplying the 5 volt standby. TVs work in a similar manner.
        • Ashroyer05
          • Sep 2013
          • 162
          • U.S
          Thanks guys. I'm learning more already.
          • Ashroyer05
            • Sep 2013
            • 162
            • U.S
            Does the psu supply a voltage to the mother boards to turn it on and then the motherboard returns a separate voltage back to the psu to have it go to full voltage? I'm confused because a tv i'm working on now it has 3.2 all the time in one pin. When I turn the tv on another pin goes to 5.18 until the screen shuts off then back to 0 but the other pin with 3.2 stays the same. OR does the motherboard operate off of standby voltage. the thing is though that the 5 v pin goes high even with the mother board disconnected, so I know the mother board is not the one sending the 5v back. So basically my psu wants to send 3.2v and 5.18v to the mother board.
              The mother board or the main board will be running of the 'ALWAYS ON' standby power supply (it can be 3.3V STBY or 5VSTBY. The stby power supply will run the minute you plug the power cord into the AC outlet, this STBY is used to run the uController or CPU (not all the function of the u or CPU will be running) which is awake just enough to get the ON signal from the soft switch or from the remote, once it receives the signal, the main board will send the signal to turn on the rest of the power supply.
              • Ashroyer05
                • Sep 2013
                • 162
                • U.S
                So the main board will send a separate singal back to the psu to go full power? Will this be on a separate pin? How much voltage does it send the 2-5?
                  For TV, the signal is usually labeled with PS_ON, or STBY, or PWR_ON. < 1VDC is OFF 2~5VDC is ON. Read basic guide below.
                  https://www.badcaps.net/forum/showthread.php?t=25810
                  You can also read the training manual.
                  • JSin21
                    Compatibility of main boards between different variations of samsung MU6100
                    by JSin21
                    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                    I have Samsung Smart TV UA65MU6100WXXY version DA01
                    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                    11-27-2023, 04:54 AM
                  • Joe24
                    Maytag Whirlpool Kenmore clothes dryer data bus
                    by Joe24
                    Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                    Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                    I've been over the board looking for...
                    01-13-2025, 06:50 PM
                  • ugamazing
                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                    by ugamazing
                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                    12-17-2024, 07:05 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • Asraf Atb
                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                    by Asraf Atb
                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                    01-27-2025, 05:02 PM
