My bulb tester...
+ More Options
Posts
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    My bulb tester...
    I read Jestine Yong's book about SMPS repair and he always suggests soldering a bulb across the fuse holder when powering on a repaired PSU for the first time... But I think this is a bit messy, and dangerous should one of the solder joint come free and touch the other..
    So for convenience I've made up this..
    So when you are testing the repaired board, instead of soldering a bulb across the fuse, you leave the board intact and simply plug the board it in to this lead.. By choosing the wattage of the bulb, you can choose with value of current to limit the circuit to..
    I just dont understand why he would suggest soldering a bulb across every circuit? Is there some advantage to his method ?
    BTW, here in Ireland.. brown is live, blue is neutral, yellow/green is earth..
  • cheapie
    null
    • Jul 2010
    • 849
    Re: My bulb tester...
    Nice!
    *goes off to build one*
    • retiredcaps
      • Apr 2010
      • 9271
      See budm's implementation
      http://s807.photobucket.com/user/bud...?sort=3&page=1
      --- begin sig file ---
      --- end sig file ---
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
      • ezenia
        LUMIMAN Smart Bulb IC ID?
        by ezenia
        I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
        In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
        04-28-2025, 05:56 PM
      • Azurain
        Elitebook 840 G5 Bios Chip Soldering Question
        by Azurain
        I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
        Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
        04-14-2023, 06:58 PM
      • JimBanville
        Replacing incandescent bulb on Pioneer LD player with led. Need help :)
        by JimBanville
        I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
        Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
        01-24-2023, 07:49 AM
      • Lifeisfun
        Trying to troubleshoot DDR4 SODIMM slot with slot tester
        by Lifeisfun
        Hi folks!
        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
        Eventually I discovered that it was related to moving the laptop.
        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
        I removed the board got one of those memory slot testers...
        06-04-2025, 02:26 PM
