recherche buffers
  • dodo6250
    • 9
    • monique
    recherche buffers
    bonjour je recherche les deux carte buffers 6871qdh089a 6871qdh088a s v p merci
  • dodo6250
    • 9
    • monique
    Re: recherche buffers
    [QUOTE = dodo6250; 323735] hello I seek both buffers 6871qdh089a 6871qdh088a card please thank you [/ QUOTE]
    • redwire
      • Dec 2010
      • 3900
      See this thread: https://www.badcaps.net/forum/showthread.php?t=22403
      eBay seems best for LG buffer chips
      • gatto
        LG 50PC56 keep burn Buffers Boards
        by gatto
        Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
        I have this LG 50PC56 which not display image on screen
        I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
        When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
        My question it is: I disconnect...
        05-04-2022, 01:35 AM
      • csmith
        LG-60PN6550 Removing Buffers-Need Help
        by csmith
        Got replacement buffer boards but not sure how to remove the ribbons. unfastened tab but their not eager to come out. Any suggestions? Thank You!...
        08-21-2024, 01:34 PM
      • telenaze
        Recherche BIOS HP pavilion DV6000
        by telenaze
        Hello
        I am looking for the bios for an HP pavilion DV6000 (RY597EA#ABF).
        Motherboard:
        30B7
        Current BIOS version:
        F.3D
        Serial:
        CNE7061GCW
        UUID No:
        434E463730363147
        4357001636EF5FAC
        Thank you in advance for your help,
        01-24-2023, 11:42 AM
      • xrey
        Replaced Y Board and Y Buffers - now no pic/no sound - Samsung Plasma PN58B860Y2F
        by xrey
        Moderator: I hope I'm not breaking forum rules or decorum by posting my original question a different way (my previous thread focused on the low vscan readings - but I'm thinking maybe that's not as relevant and won't get me as far as diagnosing as the fact that I now have no picture or sound.)
        We all of the sudden started getting a washed out picture and rainbow colored static/snow.
        Based on research when we got a low vscan reading we decided to replace the y board and y buffers.
        Now I get no picture or sound - TV turns on...
        10-21-2020, 01:27 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
