Palit HD Radeon 4850 - OvenTrick and Recap
  • alucard_t2
    • Jan 2009
    • 8
    I need some help with the above mentioned graphics card. Bought it defective because it was "almost" dirt cheap. The card gets power but doesn't give a signal, either digital or analog. Will attempt to do the oven trick. Already worked on an 8500GT, temps in my oven are between 200°C at medium flame and 230°C at max(I don't have the gas marks on the knob).
    I tooks the caps off(I would never put the board in the oven with the caps on), checked the capacitance and ESR, and have become somewhat concerned.
    These are the PSC polymer series from NipponChemicon, 820u@2.5v and 270u@16v
    The tolerance is still within the 20% tolerance but the ESR has gone a little up.
    The first one has gotten to 36-40mOhms from 5mOhms as specified by the datasheet, and the second, 65-70mOhms, up from 11mOhms. Don't know if it was THAT low when they were new, even if they're polys.
    Should I put these back or change them, might get my paws on some FMs from Panasonic, but these have higher ESR and lower ripple current rating. How much does ripple current in caps matter on video cards?
    • Jul 2011
    • 6039
    Re: Palit HD Radeon 4850 - OvenTrick and Recap
    If this graphics card has a lot of use and is an model that has been out for a while and you are getting a some what higher ESR reading
    "The tolerance is still within the 20% tolerance" are you talking about uf reading if it very near the or over - 20 % or way over the + 20%
    you will find that ESR value will change allot when you first read them the reading will be high and after just holding them in your hand a minute or two you will see the value go down almost to value that it should be
    If this is the case these are BAD
    I would change them all
    • alucard_t2
      • Jan 2009
      • 8
      I kept them. I didn't have time to check them thoroughly because the measuring tweezers weren't mine and they're also not great, so not sure about the readings. The card works and the temps are awesome, 35°C idle and 60°C under load. The only problem is this card is an animal. Might need a better power source(using two molex's to power the 6pin pci-e piehole)
      the tolerance is within the tolerance)I know. The mosfets are from STMicro, but I think the card will make it known far and wide, if its caps are failing.
      Since this is a general discusion, do you think it's a problem that the card is slightly bent because of the cooling system. It's actually a clearly visible bending where the heatsink meets the board. I think it might hurt the GPU, since the board underneath it is not flat The heatsink is crappy, big and heavy, but crappy nontheless. Might try using some 1mm or 2mm spacers on the heatsink screwholes.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Yes. This is a big part of what caused so many of the original Xbox 360s to fail (the other part was the high GPU temperatures, which with many ON-OFF cycles would crack the BGA joints).
        • alucard_t2
          • Jan 2009
          • 8
          I think I just screwed it up
          I overheated it and the laquer on the board is raised a bit.
          Also the coating on the GPU, very small area, like it's got a tiny air bubble underneath. What have my grubby lill hands done((((((((
          Can someone please look at the pics and give me good news?
          I'll be waiting with a gun at my head...
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            That's de-lamination. Happens when you apply too much heat too quickly (usually due to moisture trapped between the PCB layers). Unfortunately, there isn't anything you can do. Both the board and the GPU are done for .
            If you do occasional motherboard and/or video card repairs, keep the card for its SMD components.
            Also, if you do an over reflow next time, make sure to keep the board/card in there for for a good 10 minutes on low heat (around 100C) so that any moisture can dry out. Then after that, slowly bump the temperature up to 230C. 1 to 2 steps should be okay - first bump up to 150-170 and leave for a few (2-3) minutes, then set to 200C and leave again for a few minutes. Finally, set to 230C, leave for another few minutes, then turn off the oven, and slowly let it cool down.
            • alucard_t2
              • Jan 2009
              • 8
              You can imagine the demons I'm conjuring right now
              Should I even try it, or is it useless?
              Oh well, at least the caps are good and the cooling system is sweet..
              Might try it on an older 4850 I had. Using the backside "X" retention from the bubbly one, maybe I could keep the older "sort of" good board from bending. The old board works, but I have to reset the comp 3-5 times till it posts, after that it's all good. Unfortunately, powerful video cards are addictive. I got a taste of the power and now I want more
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                If you have another spare motherboard you don't mind experimenting with, then you can try the video card on that. Technically, nothing bad *should* happen, but I rather be safe that sorry in the rare case that it does.
                Check your power supply and motherboard for bad capacitors. I've seen this issue happen a few times due to that.
                They are indeed. A few months ago, I had an older computer (now semi-dead) that had a Radeon 9700 video card in it. Despite the video card being so old, it still kicked major ass compared to some newer on-board video cards. When that computer started crashing and I couldn't use it anymore, it felt really weird going back to a PC with a less-capable video card.
                • alucard_t2
                  • Jan 2009
                  • 8
                  That's a negatory. Both mommyboard and PSU are crystal.
                  I work in an EMS facility here in Romania.
                  I'm an engineer, and yes, I still f-ed it, and yes, you may fire at will.
                  I could try taking the card to the X-ray machine to see if the traces are interrupted but the manager will have my head on a plate replete with silicon dressing, if he sees me.
                  Will let you know if I revive Frankenboard.
                    AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                    10-01-2024, 12:46 PM
                    Thermal pad thickness for various laptop GPU / Graphics Cards
                    ASUS Dual RTX 2070 OC 8GB
                    ASUS ROG STRIX RTX 3080 OC
                    ASUS ROG STRIX RTX 3090
                    ASUS TUF Gaming RTX 3080 OC Edition
                    ASUS TUF GTX 1660 S-O6G GAMING
                    EVGA RTX 3060 Ti XC GAMING 8GB
                    EVGA RTX 3060 XC GAMING 12GB GDDR6
                    EVGA RTX 3080 FTW3 ULTRA GAMING
                    EVGA RTX 3080 TI FTW3 ULTRA GAMING
                    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                    Gainward RTX 2080 Phoenix GS Specs
                    Gainward RTX 3070 Phoenix 8GB
                    Gainward RTX 3080 Ti Phoenix
                    GIGABYTE AORUS RTX 3080 MASTER 10G
                    02-09-2024, 08:08 AM
                    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                    10-01-2024, 01:07 PM
                    AMD Radeon RX 470 / RX 580 Schematic & Board View
                    The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                    10-01-2024, 12:52 PM
                    AMD Radeon R7 340 / R7 430 Schematic & Board View
                    The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                    10-01-2024, 12:36 PM
