A bad and a good LED in series
  • kktlam
    • 27
    Hi members,
    One of my hobbies is taking apart faulty digital cameras to try to understand the problems, or even fix them. I have successfully repaired a number of mechanical issues but recently I came across an electronic issue that I hope to learn something about.
    A typical camera's LCD screen is illuminated by white LEDs. This particular Sony model I am looking at uses two surface mount "side view" LEDs to illuminate the edge of a clear plastic "glass", which is engraved with dots to reflect the light evenly out onto the "glass" surface. This particular LED circuitry is extremely simple: two LEDs in series. Somehow, it failed to light up.
    I took the panel apart and was able confirm that all the traces and contacts were continuous. When I tested each LED separately, to my surprise, they DID light up, although with different brightness. They just didn't turn on when a voltage is applied across both.
    I plan to replace the entire panel so I'm not going to make any repairs, all I wanted to know is, why would LEDs light up individually but not together? Is the dimmer (bad) LED affecting the circuit in a way that the good LED cannot light up, thus keeping the circuit open? Is there a technical explanation?
    Thanks and have a good day!
    Kevin
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: A bad and a good LED in series
    There aren't really bad or good LED series, it just depends on what application they will be used in...
    Some engineers have done a big doo-doo though, that is, overpowering the LED! This is what happens over time; the LED starts to get dim even at 'full' current!
    See those white 5mm LED's rated for, like, 30mA? NOO! A safe - non life shortening - current of more like 15mA should be used.
    Muh-soggy-knee
    • kktlam
      • 27
      ...COMPLETELY EDITED...
      I think I am misunderstanding what you meant by "bad or good LED series" ... would you explain to me as I'm new to electronics? The situation is that two LEDs are in series (ie. not in parallel) and one LED seems to be causing the entire circuit to turn off, but individually each one lights up.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        simple.the bad(dim during test)one has a very high vf now.in series this now exceeds the supply voltage.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Yes, the LED's have teensy imperfections in each, and over time these can manifest into a problem. My LED light bulb started flickering one day after one of the LED's failed, and had a very high Vf (that is why it was flickering). It was under warranty, and I just suspect it was a premature failure. Got a replacement and it has been going good for about 4 years!
          Muh-soggy-knee
            Or, a short on the camera's board where the LEDs are connected. A 3.7V or 2xAA camera will use a boost converter for those two LEDs, MLCC short would cause that fault.
            • kktlam
              • 27
              You guys are good. Well, it was not a short - just a corroded trace, but indeed on the camera board. And the whole time I thought the LEDs were broken!
              Lesson learned: next time, check the obvious things first...
              • smason
                • 1652
                Yup. I wasted a bunch of time troubleshooting a FRS walkie talkie that had no sound. Tested the earphone jack switch contacts, then started scoping the audio output. Everything looked fine.
                Had I started at the end, I would have seen audio at the speaker.
                Yep, the speaker was bad.
                A SMART troubleshooter checks for signal at the end, then works backwards, usually half way at a time, to quicky isolate the problem. Not me .
                And a cordless drill charger problem. Spent a good 45 minutes testing, measuring disassembling. It was a bad battery. D'oh!
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Corrosion can eat away at traces as you found. ModemHead documented a case on the Fluke 77 IV at
                  http://mrmodemhead.com/blog/fluke-77...per-corrosion/
                  causing the beeper and LED not work work.
                  --- begin sig file ---
                  --- end sig file ---
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                    ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                    This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-12-2024, 03:28 PM
                    ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                    This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                    This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                    This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
