Re: electromagnetic field therapy
Your meter is not fast enough to measure pulsing DC. If any one of the AND gate goes low, the out put will go low, if one of the gate is pulsing HI-LO, then the out put will be dictaed by that pin that is going HI-LO, the out put will follow that pin.
Also the voltage on the B-E will be clamping at 0.7V max (signal swings between 0 and 0.7v), so the AC value is 0.7VAC peak and it is not sine wave, your meter is also not TRUE R.M.S meter that it is trying to measure 0.7v peak to peak voltage. You need the scope to see that signal both at the Base and at the Collector.
