High Ripple Current and Low ESR
  • Braegnok
    • Dec 2012
    • 8
    Hello, I have a question about Polymer Capacitors used in motherboards.
    When comparing polymer capacitors datasheets, And all items listed are the same, except for the Ripple Current and Equivalent Series Resistance.
    Are the capacitors with higher ripple current and lower ESR, better grade?
    Example: Ripple Current 6A and ESR 5 mOhm
    VS: Ripple Current 5A and ESR 8 mOhm
    Which of the two polymer capacitors would be considered higher quality, or better grade?... And what does the (Series) refer to, does this need to match also or are there better series then others?
    Thanks in advance for any replies.
  • Braegnok
    • Dec 2012
    • 8
    Re: High Ripple Current and Low ESR
    OK, I think I'm starting to catch on.
    Lower ESR = Good
    High Ripple is prefered,... and Series is Chip type or Lead type.
    • mariushm
      • May 2011
      • 3799
      ESR is equivalent series resistance... key word is resistance ... a resistance blocks the current flow which is bad.
      So more resistance is bad, as it heats up the internals of the capacitor... lower esr is better.
      But up to a point, it really depends on the circuit the capacitor is in - some circuits DEPEND on the capacitor having a bit of resistance which is used by the circuit or IC for various reasons.
      Some circuits like the voltage regulator of the cpu needs as low esr as possible, something like a linear regulator may need low esr but are unstable if that esr value is below a specific value, for example 20 mOhm.
      That's why most people here will recommend replacing capacitors with capacitors that have the esr value as close as possible to the old capacitor's value.
      Ripple is an "up to" value, just like the voltage rating. Capacitor with 16v rating will work with any voltage up to 16v. Just the same, the capacitor will tolerate ripple up to that many mA.
      More ripple handling capability is better, but that's usually related to the shape of capacitor (diameter, height, and voltage rating) and not last, the type of materials used (polymer caps can handle more ripple than regular electrolytics)
      • PeteS in CA
        • Aug 2005
        • 3579
        • USA, Unsure of Planet
        Slight clarification. Any regulator - linear or switching - has one or more components that compensate for the ESR of the O/P capacitor. There is some tolerance in that, so the match doesn't have to be perfect, just in the right area in the ballpark. Mobo regulators happen to need the very lowest ESR possible when designed, and the regulator is compensated for that ESR. P/S regulators, being somewhat distant from the Mobo don't need the absolute best ESR, so it is possible to pick a cap that is too good and by so doing cause a loop stability problem (oscillation).
        But in pure qualitative terms: the lower the impedance (of which ESR is a part) the better; the higher the ripple current rating the better (as mariushm posted).
        PeteS in CA
        • Braegnok
          • Dec 2012
          • 8
          Thanks You guys, I have learned a lot in 3 days. Since damaging one of my capacitors and looking for a correct replacement, I had no clue how important they are in a computer. Or how they work, but it's great fun learning something useful, that can save you money or improve your stability while overclocking or building a rig using a old used motherboard.
          Thanks for all the help!!..
            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
            I tested the battery cells there are installed right now and they are testing good with no issues that I...
            02-04-2025, 08:08 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • DrewPhillips
            SFX PSU - Need High Current on 3.3V & 5V Rails?
            by DrewPhillips
            I have an older system which was built in the Windows 7 era and which has developed, I suspect, a power supply problem. The system had the same problem, random crashes, a couple of years ago, which I subsequently remedied with a new power supply.
            The power supply which came with the machine is a no-name "Safe Power PE-300". It is SFX form factor and claims a high current capacity: +3.3V @ 22A and 5V @30A (the +12V rail claims a meager 16A). Problem is that SFX supplies (or even ATX supplies for that matter) having high current ratings on the 3.3V and 5V rails seem to be...
            02-18-2025, 01:03 PM
          • harp
            high voltage high resistance marking resistor
            by harp
            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
            08-26-2024, 01:42 PM
