D2249 transistors
  • barry wilkins
    • Aug 2009
    • 172
    D2249 transistors
    Has any body got any data on these little transistors ? I did a search but could not find anything.
    thanks
    Barry Wilkins
  • retiredcaps
    • Apr 2010
    • 9271
    Re: D2249 transistors
    http://www.findchips.com/avail?part=d2249
    leads to digikey which leads to a datasheet.
    --- begin sig file ---
    --- end sig file ---
    • barry wilkins
      • Aug 2009
      • 172
      Hi thanks for your help managed to find a data sheet eventually.
      Barry Wilkins
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
      • Francesc V.
        Onkyo A8200 - Not the right voltages in some transistors
        by Francesc V.
        Hi:
        I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
        With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
        Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
        Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
        I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
        04-19-2025, 07:17 AM
      • barry wilkins
        Battery Charging Peugot Boxer
        by barry wilkins
        I am having a problem with the starter battery in my motor caravan, the makers info is very poor so I am struggling a bit with this.
        As it is Euro 6 I think the charging is done by the ECU,not the spilt charge system with relays.
        I managed to start the engine after a boost and the voltage rose to about 14 volts ,but now it is about 11.5 volts.
        It is not charging by the EHU where the 12volt power supply is.
        It is quite complex .
        Starter battery
        Liesure battery
        Solar panel
        BCA module with relays fuses and the power supply
        The fuse in...
        01-31-2021, 12:20 PM
      • redbaron1007
        Sundown SFB-8000D What are these transistors?
        by redbaron1007
        I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
        My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
        11-12-2023, 07:30 PM
      • Bob Wong
        MSI Crosshair 15 A11UEK. Need help with Transistors!!!
        by Bob Wong
        Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
        In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
        P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
        03-15-2025, 02:02 PM
