Need HP 3406A Probe Set
  • George_Race
    • Oct 2012
    • U.S.A.
    I am looking for a used probe set for the HP 3406A.
    I understand that either the 11064A or 11071A are appropriate for the instrument.
    What I would like to find is the push on BNC connector adapter for the probe.
    That would be the most useful to me.
    Can anyone help me out?
    Thanks,
    George
  • perfm2
    Wson8 spring pin probe WORKS
    by perfm2
    I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
    I recently ordered one to give it a shot and it actually worked quite well.
    The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
    I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
    This aided greatly in allowing the probe to stay in place...
    03-30-2023, 11:19 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • cheeky2
    Help with identifying missing resistor from JVC push buttons TV3024-ZC10-01(C)
    by cheeky2
    Someone previously had damaged a couple of the push buttons who has whilst pushing them in pushed off a smd resistor from a JVC 40" LED TV LT-40C550 main board MSDV3255-ZC01.
    The missing resistor off the push control buttons TV3024-ZC10-01(C) pcb is R06 see the pictures.
    I have tried downloading manuals for the Haier manufactured main board however they don't include the schematic for the push buttons!
    So if anyone has the pcb that could measure the resistance or have a schematic diagram for it would be much appreciated.
    Thanks ...
    01-20-2022, 01:35 PM
  • LearningToRepair
    How to read PCB symbol for 6 pin push-pull switch?
    by LearningToRepair
    Hi!
    I am a bit confused how to read PCB markings for 6 pin push pull switch. I had problem with my 6 pin push-pull switch on my UT58A multimeter. It did not lock properly. So I decided to replace it. I forgot the orientation of original button. And now I need some help with understanding PCB.
    I learned from google how to identify orientation of push-pull button:
    But I am a bit confused which way PCB expects it. I expected that PCB would have some kind on intent marked on it. But mine has 3 marked instead. I attached the photo of it where I marked...
    02-24-2021, 04:18 PM
