Tech Tutorial: Choose the correct capacitors for reliable automotive applications
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    While not as glamorous as microprocessors or DSPs, passives, such as capacitors, must still have reliability for auto use
    By Dave Richardson, Vishay Intertechnology
    Automotive DesignLine
    (07/07/2006 4:09 PM EDT)
    Selecting the most reliable capacitors for today's automotive electronics requires the design engineer to examine a number of different device parameters and performance characteristics. The next step is to consider the automotive environment in which the electronics will be used and the specific applications for which they are intended. Here is a look at the characteristics of the four major dielectric types of capacitors-tantalum, aluminum electrolytics, poly-films, and ceramic; an explanation of the concepts of temperature and voltage coefficients of capacitance; and how these and other factors affect the choice of capacitor for a given application.
    PeteS in CA
  • Super Nade
    • Jun 2006
    • 294
    Re: Tech Tutorial: Choose the correct capacitors for reliable automotive applications
    I didn't know Vishay Dale made caps? I know they make other passive devices like resistors, chokes, inductors etc...
    Thanks mate. That was quite informative.
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
    • PeteS in CA
      • Aug 2005
      • 3581
      Vishay is a gigantic conglomerate of bought-up companies or parts of companies. Most divisions do passives; those that make caps are BCcomponents, Cera-Mite, Roederstein, (part of) Sprague, Vitramon. Not sure whether the piece of the original Sprague does tantalums, films, or some Al Els.
      PeteS in CA
      • linuxguru
        • Apr 2005
        • 1564
        * 14-year bump *
        Vaguely related: I found a small stash of Elna RKB automotive electrolytics with nice specs: 1000 uF / 35V / 12.5 mm / 1880 mA ripple current / 135 c/ 3000 h.
        It's the combination of high ripple current, temperature and endurance that makes it interesting. Measured ESR was not too shabby either at 30 mohm - these would be great for SMPS recaps, and would probably survive fan failures.
          master hoarder
          • May 2008
          • 12175
          Very interesting find, linuxguru.
          Indeed 135C -rated caps should probably soldier through a fan failure. However, if the temperatures inside the PSU start going above 100C, I suspect many of ferrite core components will probably start loosing their properties, so the PSU will probably fail again. But at least it's good to know you may not have to do a full recap after a fan failure.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            When the fans fail in cheap power supplies what happens is that the primary side transistors desolder themselves as they get too hot and the PSU explodes, ask me how I know
            And yes, this may save both the caps and fuse, not sure much else survives though
            I think the proper solution is to have the damn PSU shutdown when the heat sinks become 100°C but what do I know since I'm not a PSU designer?
            • PeteS in CA
              • Aug 2005
              • 3581
              Originally posted by linuxguru
              * 14-year bump *
              As soon as I saw the thread title and didn't remember I'd posted it I knew it had to be quite a while ago.
              PeteS in CA
              • PeteS in CA
                • Aug 2005
                • 3581
                Long, long ago when I worked at Boschert we built up a prototype of a 750W P/S. We didn't have the inrush thermistors we needed, so we installed what was used in Boschert's OL400 series, 400W. We ran the proto at load overnight and when we came in the next morning we found that the thermistors had run so hot that they desoldered themselves and, being positioned upside down, had fallen out of the PCB.
                PeteS in CA
                  master hoarder
                  • May 2008
                  • 12175
                  Hey, that sounds like a new method of circuit protection. Just install a thermistor or whatever else with leaded (or maybe even low-melt temperature solder) and if it desolders itself, the device ran too hot. Sounds like a good way to prevent parts from blowing IMO.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Well if the PSU manufacturers are unable to come up with a logic based solution I have an idea for them:
                    Use a mechanical temperature based switch on the live wire, automatically switches PSU off when temperature gets up to its rating
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      Boschert used to have thermal switches on the L-brackets of many of their OL series power supplies. Back in ancient times ....
                      PeteS in CA
                        master hoarder
                        • May 2008
                        • 12175
                        That's a pretty good idea.
                        Actually, a lot of appliances with heaters inside (like your clothes iron, for example) already have thermal switches like that. The idea is that in case the bi-metallic switch fails, the thermal switch will open and disconnect power, thus preventing a possible fire.
                          HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          09-06-2024, 11:39 AM
                          HP ProBook 450 G6 + Spectre Tech Tote Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Spectre Tech Tote Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Spectre Tech Tote boardview and 450 G6 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                          09-06-2024, 10:51 AM
