Capacitor substitution
  • mariushm
    • May 2011
    • 3799
    Re: Capacitor substitution
    Good job. But I have to point out that capacitor AFTER the regulator is important, otherwise the 12v output will be unstable.
    • flinx
      • Aug 2010
      • 132
      That will have to wait till I have something to mount it on.
      "...off the record, unnamed government sources
      alluded to unsubstantiated innuendos about
      alleged indiscretions and insinuated that they
      are rumored not to be without basis for further
      speculation..."
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Ady2017
        Is it ok to use a capacitor with a much higher ripple?
        by Ady2017
        Hi all
        I am trying to source some new caps for the power board on my LG TV. The one I am currently struggling to find a replacement for has the specs:
        Sam Young KMG 680uf 50V with a rated ripple current of 973. According to the catalogue these seem to be a general purpose capacitor and it is not clear why LG have used them on the power board.
        I like to use Panasonic capacitors but most of these have got a ripple voltage of 2-3 times the figure of the original capacitor. My preferred FR capacitors are 3160 while the FC ones are 2215. Would going from 973 to...
        10-30-2021, 10:46 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
