Help with boost converter maths
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hi everyone I'm attempting to build a boost converter for a 16port hub it's psu only has 5volts and it needs a new fan but 12v is a load cheaper than 5v fans.
    I'm planing to use MC34063AP1G.
    What I need help with please is converting this into something I can understand
    For instance d = 3+(4-1)
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Help with boost converter maths
    You are making a fan controller?
    You know that's going to add heat too - right?
    If you run a 12v fan on 5v it should run fine, just slower.
    So use a higher RPM [or thicker] 12v fan and the 5v power source....
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Also check if these guys will ship to you.
      http://www.allelectronics.com/make-a...ING-FAN/1.html
      - Dr Seuss
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Not fan controller
        1. I have developed a interest in boost buck conversion.
        2. The fan I have got wont start on 5v.
        Thanks for the site suggestion but they won't tell me the price to nz
        Also I'm not sure I think the fan is 15mm thick and it's tight.
        My pc
        • mariushm
          • May 2011
          • 3799
          The psu of the 16 port hub may only provide a few amps of power on 5v.
          Technically, you should have 16 x 0.5A to fully power those ports, so that would be about 8A. However, I doubt the psu of the hub delivers more than 3A of power, and at such load, it would probably not do quite 5v, but rather about 4.6v-4.8v
          See for example this video, where a cheap chinese psu advertising 5v @ 1A can barely do 0.3A at about 4.6v :
          http://www.youtube.com/watch?v=T88ej...qDogWgYQcamJzV
          Next step is to keep in mind the efficiency of the step up converter which should be at about 70% ... so a 12v @ 0.15A fan would use about 2 watts of power, with the efficiency drop think of about 2.3 watts... at 5v that's already 0.5A of power.
          as for the calculations, you have to do them one after another from top to bottom...
          See https://cdn.badcaps-static.com/pdfs/...9237226842.pdf for a step down ...
          Vf is about 0.35v which is typical for a schottky diode , f is the frequency of the oscillator which you pick between 24khz and 44 khz let's say you pick 32 khz... assuming minimum 4.7v at input
          Vsat is in the datasheet...
          Figure 4 shows the saturation voltage....
          From there you just do the calculations making sure the measure units are the right ones.
          • d_ne0
            Help to identify a boost converter IC
            by d_ne0
            Hello guys!
            I am asking for help because I have an Bresser Biolux Touch 5mp microscope with an 4.3 inch tft that has no backlight.I have found that the boost ic that supposed to boost the 5v voltage for backlight is dead.The marking on the ic is : S87BaAA and is a SOT23 6 pin.I cannot find any result googling.I have replaced it with a generic boost converter and the device works,but backlight is always on,I need the datasheet of the original IC to find out how it works...I cannot find any schematics either.Maybe somebody has an idea...
            Thanks!
            01-14-2023, 01:50 PM
            HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            09-06-2024, 09:00 AM
            HP EliteBook 840 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Samsonite Base Boost boardview and 440 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            HP EliteBook 850 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
