Problems measuring mA with multimeter
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Problems measuring mA with multimeter
    This might be the previous generation of the Radio Shack multimeter? $19.99 + free shipping.
    http://www.ebay.com/itm/380349260196
    I have no experience with the seller, but thought if you like your current multimeter, and need a second, this might be a candidate?
    --- begin sig file ---
    --- end sig file ---
    • matt0177
      • Nov 2011
      • 12
      That's exactly my multimeter, for less than half price.
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
        How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
        by sam_sam_sam
        About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
        Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • jean luc ferre
        laptop hp g72 b52sf screen problems
        by jean luc ferre
        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
        i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
        06-07-2025, 03:27 PM
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
