higher volt caps ok?
    hello I am replacing caps on a power board for an lcd hdtv and i have some caps that are 50v 1uf that need to be replace. the guy at the electonirc store sold me some 63v 1uf caps?
    will those caps work or will they cause a problem?
    I would like to know before i go and replace them off the board
    thanks in advance.
    Re: higher volt caps ok?
    You can go higher in voltage without problems. If you go lower in voltage, the cap will likely explode.
    --- begin sig file ---
    --- end sig file ---
      sweet I just wasnt sure and figure i should ask first before doing the switch..
      thanks
