What is it?
+ More Options
Posts
  • killian6pk
    • Apr 2010
    • 502
    What is it?
    I thought it was a resistor, but can't identify the markings.
    Sorry for the picture quality. Bad Lighting.
    Starting from the left:
    1st color Yellow
    2nd color Violet
    3rd color Silver
    4th color Gold
    5th color Black
    Of course this could also start with the black stripe.
    Installed on its end near SMPS. The component is a medium green color overall in case you can't tell from the picture. Thanks
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: What is it?
    5 band resistors can be notorious to identify by color. Best thing to do is use a multimeter to try and identify them provided they arent burnt to a crisp.
    Also, AFAIK, black is not a color you would find on the ends of a 5 band resistor so that may be part of the problem as to why your having trouble identifying it.
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: What is it?
      http://pakheng.en.made-in-china.com/...Resistors.html
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Re: What is it?
        what does the print on the board identify it as. Rxxx Lxxx etc
        My pc
        CPU : AMD PHENOM II x4 @ 3.5Ghz
        MB : ASUS M4A89TD PRO USB3
        RAM : Kingston ValueRAM 16gb DDR3
        PSU : Cooler Master 850W Silent Pro
        GPU : ATI Radeon HD 6850
        • Longbow
          • Jun 2011
          • 623
          Re: What is it?
          .47 ohm, 5% with possible temperature coefficient (black).
          Is it plugged in?
          • killian6pk
            • Apr 2010
            • 502
            Re: What is it?
            Thanks Everyone
            Well B7000029 got the type correct it appears to be a Flameproof Metal Film Resistor. Longbow got the ohms and 5% correct. The parts list says: (RW 2WS 0.47ohm P=7.0 J ) . So what does the P=7.0 mean any ideas. I'm guessing the J is tolerance of 5%.
