APW7080 Equivalent
  • Pseudo99
    • May 2010
    APW7080 Equivalent
    OK, here goes. I have a mini itx motherboard (Aopen DE965-HG, design is most similar to a laptop motherboard), that I accidentally dropped a screw on while it was plugged in. It was not turned on, but the screw shorted two pins on the APW7080 chip, and powered on the system. I pulled the plug immediately, but not quick enough before I could tell there was a small bubble on the chip and I could smell the smoke. From the datasheet, I can tell a Taiwanese company named 'Anpec' manufactures it, and it's some sort of a step down converter. Beyond that, I am clueless as to what it does. I can easily remove it and replace it, and there is no other visible damage to the board.
    There is no replacement that I can find that I can order (Ebay, Findchips), so does anyone know enough about this thing to point me to an equivalent that I can order somewhere?
    I have a pretty good collection of dead electronics boards sitting around, but I can't find anything other than an APW7120, which I don't think is close enough to work.
    Thanks in advance for any help, you're really saving my ass on this one.
    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
    Securing a good thermal interface between...
    10-07-2024, 04:35 AM
  • Prott
    PS5 - long screw damage, via to ground layer short?
    by Prott
    Hello dear Badcappers,
    I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
    Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
    07-27-2024, 08:54 AM
  • ary89
    Richtek RT6575DGQW Equivalent
    by ary89
    i need to know equivalent and pin to pin similiarities for RT6575D, i have Asus ROG GL503 from 2017 won't charge and power on, 19v present, put the charger on and with thermal camera, that ic getting hot
    11-12-2025, 09:44 PM
  • karlox
    IC UP9002p "equivalent"
    by karlox
    Good evening, colleagues.
    Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
    Any insight or cross-reference would be greatly appreciated. Thank you in advance!
    09-01-2025, 08:43 PM
  • peter_wheat
    Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
    by peter_wheat
    Hi All,
    I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
    08-28-2025, 02:03 PM
