Replacement for ICE2AS01
+ More Options
Posts
  • billy66
    • Mar 2010
    • 124
    I need two of these chips: ICE2AS01
    Findchips shows only one place that has them... and you have to spend a min of $25 there on Quest. I don't need THAT many. I'm looking for another chip that might work. Any help?
    Thanks!
  • jetadm123
    • 2169
    Re: Replacement for ICE2AS01
    These controller chips are readily available on eBay from sellers based in the USA.
    • billy66
      • Mar 2010
      • 124
      Thanks. I totally forgot about ebay. Brain fart I guess.
      • ugamazing
        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
        by ugamazing
        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
        08-31-2022, 07:34 AM
      • feherhollo
        WSON8 NEW Bios Chips READ, ERROR, ETC.
        by feherhollo
        I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
        I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
        For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
        11-26-2023, 09:33 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
