Sanyo WX, anyone got a datasheet?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    As the title says does any one have datasheet for a Sanyo WX.
    I have one but it's for MV-WX series, I don't know if this is the correct one or if sanyo has weird way of naming their datasheets.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Sanyo WX, anyone got a datasheet?
    You will have to go to Suncon's site to see specs for Sanyo's electrolytic stuff.
    For WX, this is the spec sheet:
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Thank you, it's the same as the one I have, just different template and name.
      This confirms either FM or KZE cap for replacement.
      • mockingbird
        • Dec 2008
        • 5484
        Why replace it? It's reliable. Also, either Suncon either always made Sanyo's capacitors for them or they "bought" their capacitor division (Though for some reason, Sanyo still lists OSCON in their online catalog).
        • yyonline
          • Jul 2009
          • 692
          From what I understand, Suncon only bought Sanyo's electrolytic line. Sanyo still makes polymer capacitors.
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            My thread not getting any answers, so I'm shooting in the dark due to my inexperience, Figure might as well replace this sanyo.
            • mockingbird
              • Dec 2008
              • 5484
              Which thread is this?
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                I'll probably be reprimanded for this, but ok
                https://www.badcaps.net/forum/showthread.php?t=14442
                • mockingbird
                  • Dec 2008
                  • 5484
                  Hmmm, Sanyo WX mixed with Taicon? Is it possible someone already changed capacitors on this logic board before?
                  Also, I can't help you troubleshoot logic boards (Or even PSUs for that matter) as I am a complete ignoramous when it comes to these matters. Plainbill can help you.
                  • electomech-fixer
                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                    by electomech-fixer
                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                    Today, 01:42 AM
                  • SoulFreeze
                    Help finding datasheet for component marked G34662
                    by SoulFreeze
                    Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
                    Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
                    Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
                    05-01-2025, 03:56 AM
                  • Rainbow_Chameleon
                    Searching Datasheet for AM113 IC by O2MICRO
                    by Rainbow_Chameleon
                    I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
                    Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
                    If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
                    On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
                    So if anyone has a datasheet or at least...
                    01-23-2025, 12:03 PM
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                  • cj_reha
                    Mystery 80s Sanyo cap - perhaps polymer?
                    by cj_reha
                    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                    01-06-2023, 09:24 AM
