Earth loop problem ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I got an Asus VW222U, according to Asus forums it has an earth loop problem.
    http://vip.asus.com/forum/view.aspx?...Language=en-us
    http://vip.asus.com/forum/view.aspx?...age=1&count=19
    1.open monitor (will void warrenty)
    2.unplug all the the cables going to the power supply and dvi port assembly, undo two screws pull down and out you wil now be looking behind the dvi port and be holding a metal module that contails power supply and dvi- and vga port.
    3.you will notice a piece of brass foil joining the earths on your dvi and vga cable this is the problem creating an "earth loop" as both vga and dvi ports are earthed to the metal casing this extra earth is causing the problem introducing noise.
    3.carefully unwrap the brass foil from the two cables and seperate, insualte cables with electrical tape. (wrap around each one seperately they should now be indiivdual cables)
    4.you will notice a silver spring type peice of metal on the assembly that pushes against the
    main body of the unit when re-assembled. scratch the metal with a screwdriver where this peice pushes so you get a good connection when you reassemble it, do not touch as finger grease could screw up the connection. (this step is not vital just a good thing to do why your in there to make sure the the unit is properly earthed)
    4.re-assemble
    Added a few pictures for you to see.
    Is this considered a smart move or should I skip it ?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Earth loop problem ?
    were you having trouble with noise before?
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      I found this monitor among garbage at work, it was completely dead but all it took was to resolder the powersupply board.
      It is working right now but since I now have it apart I was wondering if this mod would be helpful and safe to do.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        I would test it first if no problems then leave it alone.
        • retrorepair2
          ASUS GL553VD power loop problem
          by retrorepair2
          I have the above here (i5, gtx1050) that had liquid damage, replaced 3 mosfets, cleared all shorts now tries to power up and power, caps lock and charging lights flash for half a second then hdd light just blips every half second forever.
          BQ IC looks fine and definitely no more shorts, power rails are pulsing along with reset, can’t work out what the issue is, does anyone have experience with a similar fault?
          someone else posted they had this issue and tried reflashing bios but didn’t solve it.
          08-22-2025, 10:36 AM
        • lazaro.089
          Asus Zephyrus M16 / GU603ZW problem
          by lazaro.089
          Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
          CPU: Core i9-12900H
          Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
          Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
          The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
          08-26-2025, 06:33 PM
        • AtelierRepa
          ASUS X712JA problem
          by AtelierRepa
          I have a problem with the bios, let me explain.
          With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
          I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
          My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
          The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
          06-15-2024, 04:33 AM
        • Dobrowol
          Asus GA402RK keyboard and kb backlight problem
          by Dobrowol
          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
          04-28-2025, 04:30 PM
          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
          09-07-2024, 02:50 AM
