Understanding datasheets without impedance listed.
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Ok, so I have a Ost RLG 10uF 50V I need to replace.
    In the datasheet it is listed as 45mA and no impedance is shown except this listing I attached.
    Does that mean it has an impedance of 2.0 and a proper replacement can be a Nippon CC LXY 103mA with an impedance of 1.9 ?
    I put the RLG datasheet for you here if you need to see the datasheet.
    Also I have a KSC GL 2200uF 10V 10x20 that has popped - the closest cap in their datasheet is 13x25.
    Is it right to say that the ripple of the 13x25 is 1710mA with an impedance of 0.045 or am I totally lost ?
    I also see that it is listed up to 200KHz, should I be worried by that when I look for a substitute as they normally are listed up to 100KHz ?
    I put the KSC datasheet here for you.
    Any help will do, Thanks.
  • mockingbird
    • Dec 2008
    • 5488
    Re: Understanding datasheets without impedance listed.
    I find that the general purpose caps don't have the impedance listed but they do have something called "tan" instead. I've asked before what it means, but no one knew it seemed.
    What I was told was to just match the ripple on GP caps, make sure it is equal or greater and don't worry about the impedance.
    • japlytic
      • Oct 2005
      • 2086
      If the datasheet does not mention 'high frequency' use (e.g. lighting ballasts, PFC stage) or an ESR value, generally, they are not designed for high frequency power supplies.
      • bigbeark
        • Jan 2010
        • 661
        Yes you have decoded the Ripple and Impedance correctly. Bottom line these caps are crap.
        They are NOT low-ESR, low-impedance caps. Maybe OK for a power supply, not for a motherboard
        • marcus905
          • Jun 2011
          • 37
          If i'm not mistaken it's "tan delta" and it's the thermal dissipation factor.
          • Longbow
            • Jun 2011
            • 623
            The TAN column refers to the term 'tan loss' or the tangent of the phase angle between resistive and reactive components of the cap. This figure is a little more informative than a straight ESR reading, but harder to interpret. The lower the number, the lower the resistive loss component. In daily practice, an approximate ESR value will be sufficient. For initial circuit design purposes, the tan loss figure is more precise.
            Is it plugged in?
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
            • Stefo
              Help Understanding Darlington IC
              by Stefo
              Have a question above my understanding. (see attached pic and datasheet). Attempting to repair a pcb with a burnt out Darlington Transistor IC. I have identified all pins except for nos. 11 & 12 (Output 7 &8). I removed what is left of the IC, but could not find any traces as to where these pins might have been connected. Bad choice of words, there is no trace of any circuit trace for either pin. In the surrounding circuits i cannot find any without a verified connection to other components. My question is it possible these two pins are just hanging out there with no connection, nothing...
              01-11-2024, 09:14 PM
            • P4C800
              ASUS P5A and P2B-S recapping. Searching old datasheets.
              by P4C800
              I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
              There are three mainboards:
              - ASUS P5A rev 1.04
              - ASUS P2B-S rev 1.03 "Rubycon"
              - ASUS P2B-S rev 1.03 "Chemi-Con"
              If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
              They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
              P5A
              10-09-2023, 05:55 AM
            • CdDvdFlash
              Please teach me how to find datasheets to obsolete caps
              by CdDvdFlash
              I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
              (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
              08-12-2023, 12:29 PM
            • Tomek188
              Looking for datasheets for EN7521 and MT7520
              by Tomek188
              I need datasheets for EN7521 and MT7520 (similiar chips). This is GPON ONT.​
              01-17-2025, 01:47 PM
