Aluminum caps
  • kiddznet
    • Jul 2010
    • 176
    Aluminum caps
    A cap fell has off a vid card .What is the best way to get it on using a soldering iron?
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • severach
    • Aug 2007
    • 1055
    Re: Aluminum caps
    For SMD caps, apply flux to each pad. Mix a small amount of 63/37 solder in with the existing solder on the pads. Do it quickly and the flux will leave smooth mounds. With the lead solder mixed in the melting point will be much lower and your soldering iron will be able to heat each end as you push the cap down without burning the cap up. Clean the flux with swabs and alcohol or brake cleaner. The cap won't attach as strong as the original solder work but this simple technique works for me.
    If you have two soldering irons and two people, one person heats the two sides and the other person pushes the cap in. That will result in very strong solder joints and some burned fingers.
    sig files are for morons
    • skystormfarms
      Banned
      • Mar 2011
      • 160
      Re: Aluminum caps
      hay some times you need to burn some fingers to repair stuff
      • Agent24
        I see dead caps
        • Oct 2007
        • 5086
        • New Zealand
        Re: Aluminum caps
        I would try what I saw on a Youtube video...
        Apply flux then tack one side of the capacitor with a tinned iron tip, then solder the other side by laying solder 75% the way across the pad and bringing the iron tip in, then back out after the solder has flowed (chisel tip works best)
        Repeat with the other joint, clean off flux.. here's the video anyway: http://www.youtube.com/watch?v=_IqJdJEMUOE
        -David VanHorn
