detecting heat with IR LED receiver
  • harp
    • Jun 2022
    • 613
    • Planet Earth
    I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
    So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
    Something like termal camera, but in one spot, any simple circuit?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: detecting heat with IR LED receiver
    Those IR sensors are of the wrong wavelength and won't work very well if at all.
    Non-contact "laser" thermometers are basically what you're looking for - one spot heat detector.
    • redwire
      • 3912
      The human body emits far IR around 12 micron wavelength, 36°C strongest at 9.4μm. This is far away from any photodiode or phototransistor's response.
      A Pyroelectric Infrared Sensor does detect it but only if it is moving.
      • harp
        • Jun 2022
        • 613
        • Planet Earth
        Yes I know for pir sensor, but dont have some...
        I read the article seamlessly it is very informative, I didnt know that pir sensor is type of cheramic, and how act to bring sensing to meter, it is some sort of "capacitor"...
        I found that is very common using regular diode as temperature (ambient) sensor, due to characteristic of changing properties depends on it, about 2mV/C
        so, I think, that some properties will also changd in ir receiver led if it is exposed to heat radiation. But cant measure and get any clear conclusion beside of light depend properties even in this dark package... The diodes was desoldering from vhs video, from tape end detecting.
        • wolf1976
          wireless receiver for 6 speeds fan control with remote control
          by wolf1976
          hi i have a receiver that is destroyed from the overvoltage i guess
          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
          the motor fan has not label
          i have an other receiver operational
          In your opinion can i measure the voltage at the output ?
          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
          thanks in advance...
          07-23-2025, 03:12 PM
          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
          Securing a good thermal interface between...
          10-07-2024, 04:35 AM
        • CdDvdFlash
          DSE GE6878 possible TV receiver dying remote not working well
          by CdDvdFlash
          For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
          07-03-2024, 03:55 AM
        • Cornito
          Denon AVR-2700H audio stops while receiver still works
          by Cornito
          Hello team,
          I've got a new issue with a Denon Avr-2700H.
          After several minutes working, receiver stops playing sound with a poc eared in the speakers.
          Receiver still work and display video with error message on display.
          Seems to me that is the main output relay.
          I'm looking for the service manual that I can't find for the moment.
          Does somebody have it?
          Regards...
          08-03-2025, 06:10 AM
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
