Mismatched caps?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Mismatched caps?
    Originally posted by We Rig Math Tests
    I got a replacement cap with the right rating, and put it in. Then I did something stupid. I had the PCB plugged in for testing and I picked it up carelessly, zapped my thumb, and now nothing will turn on or light up, not even the power indicator. I'm assuming I shorted something because without a cap in it the front LED would come on and the backlight would flicker and die. Time to give up.
    Odds are you just blew something in the power distribution and that is usually repairable.
    Repairing or not depends on how much work you feel like doing.
    Mann-Made Global Warming.
    - Dr Seuss
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
