RE-125 RF generator
  • Maxxarcade
    • Jul 2006
    • 973
    RE-125 RF generator
    Anyone here ever heard of a company called "RE Technology AS"? They are a company from Denmark.
    I have an RE-125 signal generator that I really would like to find the manuals for. I've figured out how to operate it fairly well on my own, but there are a lot of things I don't understand on it still.
    I have a short video about it here if it would help.
    http://www.youtube.com/watch?v=j7iHZi-evfE
    Any info on this thing would be greatly appreciated!
  • Krankshaft
    • Jan 2007
    • 2328
    Re: RE-125 RF generator
    Damn I'm still using a tube RF generator to align my tube radios .
    • Maxxarcade
      • Jul 2006
      • 973
      I was until now, and I was fine with my Eico 324. The problem was, I had no way to do FM tuners with it.
      The other advantage of this one is, the on-screen frequency is right on. No need to use a separate counter for accuracy.
      Now if I could only find a distortion meter for cheap...
      • Dannyx
        Wind generator charger schematics (or load of baloney ?)
        by Dannyx
        Good day folks. A former colleague of mine recommended me to a relative of his and I got to speak to this man today in person. He's a bit of a mad scientist/tinkerer sort-of guy - just my kind of weirdo Apparently this chap builds all sorts of generators and wind turbines in his little shop at home and sells them here and there. He even showed me some footage of some of his inventions in action out in the field. However, as he himself very kindly put it, he's not good with electronics - he just designs and builds the generators (from scratch, I might add) and turns to others for the electronic...
        09-16-2022, 11:13 AM
      • PM5K
        Inverter Generator Repair
        by PM5K
        I have an inverter generator that has two bad caps. One blew and the other was swollen.
        My main issue is that the power supply
        is encased in some type of epoxy.
        My main concerns are regarding the epoxy and its purpose. I can imagine that it helps with vibration should I also be concerned with sparks since it's a gasoline generator?
        The plan is to break off the old caps, cut the old legs off, clear out the solder points, then solder from the top since I cant get to the backside of the board.
        This means that the legs of the caps...
        01-13-2023, 03:15 PM
      • jheunne
        Company Accounton windows possible to remove
        by jheunne
        hi there i have a lenovo k14 gen 1 i installed clean windows 11 but it ask for company account like microsoft acount i tried to skip but i end up on still asking for company cognizant account. is there a way to unlink or unbind this account on the unit? thank you.
        04-18-2024, 10:25 PM
      • jason123
        Agilent 33220A 20 MHz Function Generator
        by jason123
        I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
        So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
        1. Turn the output off - still...
        07-01-2025, 08:12 AM
      • Crashpro2003
        Wanted: Reputable and responsive PCB repair company name and contact info.
        by Crashpro2003
        Been getting pretty tired of searching for and contacting PCB repair companies online. Filling out the company's Quote Request forms, explaining the problem, attaching photos then sending them out and hearing nothing back. Have done this at least 5 or 6 times and not one quote. Why is this? Don't these companies need or want the work? If anyone knows of a company that will do what they say, as in, supply a quote for a PCB repair. Or at least respond to me. Please let me know their name and contact information. I will be tremendously grateful. Thanks
        12-08-2022, 02:40 PM
