DIY | TESTER for LED TV BACK LIGHT
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    Hi I ask you if this Diy backlight tester does it really work? this uses a bridge rectifier exp: TS4b05 where test wires go from + and - then a resistance of 10k ohms on an AC input. according to the video it works but I would like your suggestions please
    here the video:https://www.youtube.com/watch?v=LI6iudt2hgk
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    Re: DIY | TESTER for LED TV BACK LIGHT
    Yes... but only if you're felling lucky getting a 230V electric shock
    Plus the resistor will keep burning
    Stay SAFE and away from obvious hazards!!!
    [Any decent rescued ATX power supply, or even a power supply adapter, will do the job]
      • Jul 2011
      • 6037
      I have safely concerns about your idea about building this device project
      You need use extreme caution using this device if you do use caution using the device you have in mind then I do not see a problem doing it
      However I would also think about using a VARIABLE TRANSFORMER
      I have made a testing jig for testing 110 DC solenoids and I did something very similar I put in a plastic enclosure and alligator clips on for easy use
      But I was fully aware of the risk of using this device
      I have also made other testing jigs for testing devices that you have to use extreme caution using them
      Just be aware of what you are doing when you this device
      • bohaboha
        • Nov 2012
        • 973
        • sweden
        Thank you megaraider and sam_sam_sam of corse i am looking to my safety
          master hoarder
          • May 2008
          • 12170
          YES, this tester will work... but it's NOT safe!
          Let's do some simple math here. The video suggests to use 10k resistor in series with one of the AC legs on the bridge rectifier. With 220-240V AC, that limits the short-circuit current to:
          I = V / R = 230 / 10000 = 0.023 Amps... or just 23 mA. (or 22 mA for 220V AC and 24 mA for 240V AC.)
          Depending on the LEDs you're testing, 23 mA could be too much and burn out the LEDs.
          But forget about the damn LEDs! 23 mA of current at line voltages of 220/230/240V AC is plain dangerous. That kind of current may be enough to not being able to let go if you happen to touch the any of the live parts. Worse yet, it's DC after the bridge rectifier, so your muscles may only clamp in one direction. Not to mention the guy in the video is holding the live wires with both hands - a good way to send a shock across the body.
          Therefore, I don't recommend anyone to build a device like this. It's honestly a little more than silly. I do my fair share of silly crap too, but at the very least I never hold a high-voltage source with both hands, and I'm usually pretty well insulated from ground. If you really have to make a device like this, then use jumper wires to make connections before plugging in this "device"/contraption into the wall, so that you're not actually holding onto live circuits during testing.
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
          • PNI E.
            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
            by PNI E.
            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
            02-20-2025, 08:36 AM
          • koby058
            vostro comes up with back light but no picture
            by koby058
            Hi people!!
            The owner said it showed bad picture once in a while (attached)
            I see that there is back light but no picture.
            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
            Also attached schematic and BDV
            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
            07-13-2025, 01:03 PM
          • Green Probe
            Recapping a Denon AVR X6400h SMPS
            by Green Probe
            (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
            Disclaimer: I'm an amateur hobbyist and will get things wrong.
            Always use caution when working around mains power and high voltage capacitors!
            Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
            SYMPTOMS:
            -No display...
            07-18-2025, 03:36 PM
          • triplefour
            TCL 75S421 has sound but no backlight not even a flash
            by triplefour
            TCL 75S421
            PSU BOARD: 40-L402H8-PWD1CG
            it shows not even a flash of backlight when powering up.
            but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
            testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
            unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
            i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
            with mb connected, PSON...
            11-17-2023, 09:54 PM
