Oscilloscope UNAOHM G4020 = BECKMAN 9020
  • neuron
    • Feb 2013
    • 126
    • Portugal
    #41
    Re: Oscilloscope UNAOHM G4020 = BECKMAN 9020
    Originally posted by eccerr0r
    Actually measuring the voltage at each H-deflection plate when there's nothing displayed might be interesting.
    CRTD1, CRTD2??? R971 and R972
    OR Colector T908 and T909
    And CRTD3, CRTD4 no interest. ???
    CRTG2 +140V?
    The -1,9KV any arch ? Distance
    And the other 260V ... 140 V? distance
    https://en.wikipedia.org/wiki/Paschen%27s_law
    https://sciencing.com/calculate-volt...s-8776030.html
    " ... debugging my Tektronix 2465 ... "
    Can you give details?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Yes CRTD1, CRTD2 which are the collectors of T908 and T909.
      I currently have absolutely no interest in CRTD3 and CRTD4 because you have yet to do any experiments for us on the V-scale, there is no value on obtaining those readings until you do the V-experiments (i.e. hooking an actual sine wave to the vertical inputs, which you have yet to do). Not only the experiments weren't done, it may end up showing the V-deflection is working just fine and it would be superfluous to list those measurements.
      CRTG2 and CRTG1 are unuseful numbers because we see the beam hitting the second anode, implying those values are in range. Again we know the second anode, cathode and grid voltages are within range or at least sufficient enough to display *something* on the screen so we will have to at least assume those are usable to do something for now. It may very well be those voltages are affecting the trace such that it's shrunken down, but we'll get there when we get there, plus unless someone has an identical, working scope to compare with, we have no idea if those voltage values are correct.
      Again, do the experiments asked, everything else is on your own to interpret because whatever you do, we don't know what the conditions are that generated that number hence we ask you to do something and get the data that's the result of that thing we asked you to do. Any excess data you post likely will be forgotten/ignored and asked again, do so at that time, it takes less time for us to read one post than have to go through every post again to look for the number we're now interested in.
      Please also measure all the power supply voltages and make sure they're within range... this should have been the first step. Fill out the table:
      What is the voltage pin
      +24V... ____
      -12V ... ____
      +5V ... ____
      +260V... ____ (WARNING! Danger)
      +140V... ____ (WARNING! Danger)
      Again we have to assume the CRT voltages are correct for now because it lights up green. Better that we don't have to measure them because these are the dangerous high voltages. These voltages would be important if we do not see anything at all on the screen.
      My Tek 2465 was acquired broken, and I broke it more when trying to debug it. Eventually I found by step-by-step debug that first I destroyed the CRT by bending the pins too much, then destroyed the vertical amplifier due to an inadvertent short (found by using another scope on the vert amplifier input and output pins) and then found one of the focus amplifiers was nonfunctional - the knob was not working and traced to an op amp that was destroyed due to the initially destroyed CRT. A simple multimeter found that second issue.
      • neuron
        • Feb 2013
        • 126
        • Portugal
        #43
        Thank you
        My problem is if I get burn with this ... volts.
        For the +260V +140V I need put the probe there and
        then and only then power the Scope?
        or we can proceed like +5, +12 V in computers ... no
        arc?
        And I ask in previous post if I get the probe near
        5 ... 10 cm from the tube ... I get an ARC? and
        PUFFFFFFFF.
        That so talk and no test ...
        And The Scope never ... work?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          If you're careful you can do it while it's powered up. It would be good to carefully choose a point where you won't slip a probe. You should never get an arc on these supplies, if you do, you probably ruined it. The warning is there so that you don't create a circuit from these points through your body. It's about the same danger as working with mains voltage.
          You shouldn't get an arc near the tube either. It should be insulated enough that you can get near it without any worry. In fact usually the chassis around the tube is grounded and the insulation should be strong enough to not allow an arc. If you do get an arc, that's a problem that needs to be fixed. We're not blaming anything yet with the second anode (the big red wire) or the cathode/grid/heater voltage (the back circular plug) so don't worry about it yet. The deflection plates, however, are a symptom that needs to be investigated. Chances are, your deflection plates are hooked up to the back circular plug so I may be wrong on the fact you don't need to touch it, but you can tap off of the collectors of the transistors too. Just treat the voltage with caution. Wrap your multimeter probe tips with electric tape so that only the tips are exposed. Improvise.
          My Tek 2465 has separate connections for the deflection plates so luckily I didn't need to touch the back for the deflection testing. But when I didn't get any beam at all, then I needed to check the -2450 volts on the cathode and needed the sole multimeter I had that was 5KV rated: an old analog Eico meter...
          • RepairMonkey
            • Jul 2018
            Don't overlook something non technical. Check for dry or cracked solder joints - especially on components subject to mechanical stress i.e. transistors on the PCB that have a heat sink attached to the chassis, board to board connections. You'll need to clean away the crusty flux to see all the solder joints cleanly but it could be as simple as that.
            • neuron
              • Feb 2013
              • 126
              • Portugal
              #46
              My Tek 2465 ...
              Amazing DataBase !!!
              And Tek is Up and Running?
              Thank you
              With Acetone, Benzine, Konkat ...?
                • 31055
                with isopropanol
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  My 300MHz 2465 is working just fine now. Some may find it shocking all I needed was my old 20MHz 'scope.
                  I used the 2465 to subsequently fix my Tek 2440 which was also acquired malfunctioning ... there were no visually damaged components. Anyway, I tend to try to use the 2440 when it makes sense as it's my only DSO.
                  To clean flux, it depends on what kind of flux, but be careful with the solvents that destroy plastics.
                  • neuron
                    • Feb 2013
                    • 126
                    • Portugal
                    #49
                    Originally posted by stj
                    with isopropanol
                    Clean the front panel - Knobs, Handles, Pulls and Switches what you suggest?
                    And you have videos ?
                    Or text explan the process ?
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      No, I don't do videos, the makers never intended me to make videos as I learned in high school. What I've posted in this thread is probably to the extent of any documentation I have about it, and perhaps some other posts I did about it on badcaps.net while I was trying to figure out how to definitively prove I broke the CRT...
                        • 31055
                        no, it could remove the print.
                        for cleaning circuit boards.
                        • neuron
                          • Feb 2013
                          • 126
                          • Portugal
                          #52
                          bad/dirty contacts,
                          Inside ... pot, potentiometer ... switch contacts,
                          carbon pelic.
                          Thank you eccerr0r
                            • 31055
                            for pots & switches you need contact cleaner
                            • neuron
                              • Feb 2013
                              • 126
                              • Portugal
                              #54
                              What you use? brand model
                              And eccerr0r in 2465 ... Tek 2440?
                              • redwire
                                • Dec 2010
                                • 3910
                                You need a cleaner AND lubricant.
                                I am trying Caig DeOxit Fader Lube because it is compatible with conductive plastic and carbon potentiometers.
                                So far, it works but is expensive and has very little lubricant. I think it's 5% mineral oil. If I spray it on a paper napkin, hard to see any residue there.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Yes the two Tek scopes I have are the 4-channel Tektronix 2465 computer enhanced analog and the 2-channel Tektronix 2440 DSO. The 2440 is a primitive DSO with depth of only 1024, but that's the technology that was available then.
                                  As for the contact cleaner you should be able to tell with a multimeter whether you're exhibiting contact problems. And we mean the insides of the pots and switches, not the external appearance of course.
                                  • neuron
                                    • Feb 2013
                                    • 126
                                    • Portugal
                                    #57
                                    Thank you
                                    In local stores:
                                    MOTIP
                                    https://www.motip.com/products/motip...ntact-cleaner/
                                    https://www.wd40specialist.com/products/contact-cleaner
                                    http://cyclo.com/cyclo_product/break...onics-cleaner/ 87
                                    http://cyclo.com/cyclo_product/break...ntact-cleaner/ 85
                                    Any use in your equip.?
                                    • neuron
                                      • Feb 2013
                                      • 126
                                      • Portugal
                                      #58
                                      It's working and calib.
                                      Thank you for all info and support,
                                      Ruy
                                        HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                        09-12-2024, 03:44 PM
                                        HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                        09-12-2024, 02:00 PM
                                        HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
