What is a good de-soldiering iron/tool?
    replied
    Re: What is a good de-soldiering iron/tool?
    Try this one I have not used this series before “KYB” but I think it looks very similar to “KY”
    This one is 2700@35 volts
    https://www.digikey.com/products/en?...272MK40S&v=565
    I going to buy some of these caps and try them in my units and see if it likes them or not
  • evilkitty
    replied
    May i ask why you linked a 25v cap?
    anyway i found a FR cap
    EEU-FR1V222L 2200uf 35v 12.5mm dia
    EEU-FR1V471, i assume the 470uf should be upgraded to 35v also (otherwise i can use a EEU-FR1E471Y)
    That bar only holds 2 of the 3 ICs
    replied
    I forgot that this one had the metal bar that held all three IC chips in place
    You do not have to do anything what you have with work just fine
    I have work on so many different devices lately I guess mess up on this
    These caps will be fine UKL1H100KDDANATD
    The two 2200uf@35 volt caps are a FR series will be the only that will right
    right now I cannot find the bag tag for those caps that I had used 3300@35 volts I will see if I can find the ones that I used
    This will probably fit ( KY 2200uf@35 volt ) diameter 12.5mm
    https://www.digikey.com/product-deta...1560-ND/756076
    The 3300uf @ 35 volt one starts with 16.00mm which will not fit
    I guess they do not have the 12.5mm anymore
  • evilkitty
    replied
    so as for the 50v 10uf caps are low leakage Nichicon UKL good for those? UKL1H100KDDANATD (I have these on hand)
    no need to replace the large 400v cap?
    should i put some electrical tape on that bolt?
    the bolt is in contact with the heat sync, none of the 5pins on the IC show a connection to the heat sync
    I attached a couple pictures of how it looked whit the heat sync in its original state *i suck at editing so i tried to remove my legs as best i could cause i am not a attractive female
  • evilkitty
    replied
    Originally posted by sam_sam_sam View Post
    There are two plastic washer one on the screw “head” is one that has a tapered ring that fit in the mounting hole to the heat sink on the chip side there is where the other plastic washer goes then the flat metal washer then the lock washer then the nut
    Do not put the wrong plastic washer in the wrong side of the heat sink
    When you put it back together check the screw that holds the power supply regulator IC chip that there is NO resistance between the screw and the heat sink
    so when you say no resistance do you mean r=0.0000000 or r=N/C (infinite)
    that statement seems like a possible 0 == False vs 0 === False issue
    replied
    Originally posted by evilkitty View Post
    so with this component is there was nothing between it and the heat sync it would short 120v AC to earth ground?
    If so how do the bolt threads not short it? Is the bold itself not conductive?
    replied
    the pump looks to get power from a black box mounted at the back of the unit (next to a under voluted 24v fan) that contains two 5w resistors and the low side of the pump goes to the gun
    aside: really that fan grill is shit, either use a honeycomb design or cut big hole and use a cheap wire grill, wait a min this fan in a intake i thought it was exhaust
    the only transformer i can find is on the power supply
    Look in the black plastic box and see if there is a capacitor on that board if there is replace it as well
    That fan grill is ok it moves enough air surprisingly enough it is the intake side of the fan
    There is a very thin gray insulation pad on the back of that switching power supply regulator IC chip the one you circle in that photo
  • evilkitty
    replied
    From where the two red wires are to the yellow transformer on the same side of the red wires are the hot side the other side of the transformer is the low voltage side of the transformer no it was not a typo
    I hope this helps
    replied
    test it with a known good lead if you dont want to test the one it came with.
  • evilkitty
    replied
    Originally posted by stj View Post
    if your looking that closely, find out how the trigger controls the pump.
    on the older transformer type ones, it was just direct and the switch & cable got hot.
    a solid-state relay was a good upgrade.
    replied
    not sure if you thought that was a typo or you made a typo
    were you saying the choke should receive 120V ac at the PCB OR the back of the IC by the cap is hot
    I hope this helps
  • evilkitty
    replied
    On that note is the back one by the large cap hot or ground,
    The black one is on the hot side of power supply to the outlet
    replied
    replied
    I will let you know tomorrow
  • evilkitty
    replied
    My "insulation disk" has corners, i do not think i can call that a disk...
    Do you have a list of replacement caps that will fit the board from where you replaced them in the past?
    not sure if it will fit as i have not taken measurements, but EEU-FR1V222L 12.5mm dia 3.5cm tall 2200uf 35v
    about the pin set i was asking about the part at the I wanted to make sure the lead from the switch to the PCB was correct
    time to get some sleep...
    replied
    i would expect the bolt going through it could have the threads touch the heat sync let me circle it, that one had 3 disk between the IC and the nut
    Nut -> Red pad -> red pad -> red pad -> IC -> paste -> pad -> Heat sync -> lock washer -> bolt
    i put it back like this
    Nut -> red pad -> red pad -> IC -> paste -> pad -> Heat sync -> Red pad -> lock washer -> bolt
    should i clean of and apply new paste like i would for a CPU's heat sync?
    The insulation disk (which is gray in color) goes between the IC chip and the heat sink
    The screw should have a plastic washer on the heat sink side and chip the washer and lock washer and then the nut make sure that chip has these parts on it
    have not powered it on, stj said the mains wire may be reversed, so i wanted to check that 1st, but not sure which side should be Line and Neutral, i know the power switch goes to the yellow brick 1st, i would assume the switch should get line, but i am not sure if he meant the wire to the switch or the wire to the board
    When you look at the outlet
    The pin on the right side is the line side
    The pin on the left side is the neutral side
    The bottom on pin is the ground side
    The fuse should be on line side of the plug if it is not then it should be but check with another cord just to make sure it is not cord that is wired that is wired wrong
  • evilkitty
    replied
    And that you put heat sink compound on those three components on the heat sink and make sure the insulation disk are in place and the screws are tight
    On that note is the back one by the large cap hot or ground, i would expect the bolt going through it could have the threads touch the heat sync
    Does your ZD-915 shows “U1” or “U3” if yours is “U1” or there is nothing on boot on the screen then you have an older version of this unit
    replied
    which component should be +120v ac, the black disk or the yellow brick? (center image left side)
    That is the switching power transformer and the component with either 5 or 8 pin that is the switching power supply regulator IC chip in the first photo it is one on the left the one in the middle and the one on the right are for the heater and the other one is for the vacuum pump but I can not remember which one is which without looking at the board again
    The black one is the choke coil for electrical noise filtering with the caps that are near it
    replied
    If you put the 3300uf@35 volt caps in it is going a very tight fit
    When you order the caps make sure of the diameter
    When you look up the 2200uf@35 volt caps you see that 3300uf@35 volt has a bigger diameter
    Also make sure that that you replace the 10uf@50 volts
    The two caps on the temperature controller board it would be a good idea to replace them put 35 volt ones instead of the 25 volt ones
    I would order both just in case you can fit them in way you want to
    I had one of my ZD-916 soldering iron LED black light went black I have a couple of controller boards that have issues so I replace it and now the back light works again
    You might have a problem when it is cooler than 75* F it might restart a few times before it will stay ON there is a work around if this case I will share with what you can do for it to work right
  • evilkitty
    replied
    23 screws later...
    looks like the same unit sam sam sam has with those 25v 2200uf caps that should be 35v
