Scottle IR6000 problem
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have a scottle IR6000 which has a very strange problem.
    The BGA station has 10 programs but only program no 5 works fine all other programs stop on step 1 whatever time or temperature I give.
    In program no5 every step is working and it finish the program.
    Does anyone else has this BGA station and similar problem/solution
    Thanks in advance
  • asus61
    • Jan 2020
    • Italia
    Re: Scottle IR6000 problem
    sorry if I write in your post I need help; I have no experience on these stations; I bought one like yours I think and without sw and driver you could help me.
    • peste
      • 13343
      • ROMANIA
      I have one as well ... what problem do you have ???
      • asus61
        • Jan 2020
        • Italia
        I'm sorry if I answer so late; I only have the machine but no sw and profiles so far I have only done some desoldering of some processors using it manually but I would like to use it with the PC can you help me
        • khaledmus
          Problem with hot air station LK852D-2
          by khaledmus
          Hi, i have a hotair station LK852D-2 , and the problem is about the air flow is little and hardly to getout any air flow from it, i unfurtanitly replaced the potinmeter 500k ohm with new one, but it never solved the problem, and then i unsoldered from the board as you can see in the attached photo, and that make Some parts of the circuit diagram been damaged, and I need someone who has the same circuit diagram to provide me same photo of the diagram, especially the place where the 500 kΩ potentiometer switch is located( the place of 500k ohm potentiometer is indicated it with red arrow in the...
          09-12-2025, 04:39 AM
        • khaledmus
          problem with hotair station LK852D-2
          by khaledmus
          09-11-2025, 07:47 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
          09-07-2024, 05:20 AM
