Seamark ZM-R6200 Rework station
This topic has been answered.
  • shahnld
    • Nov 2019
    • 159
    • Netherlands
    Good day Experts.
    I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
    Kind regards
  • Answer selected by shahnld at 01-26-2024, 03:26 PM.
    mon2
    • Dec 2019
    • 14250
    So far we have used on our custom 4L PCB designs to remove / replace BGA and TQFP devices only. An older model from Seamark was used by Louis for GPU repair.
    Zhuo Mao ZM-R6200c for Macbook Pro logic board repair, 2011 GPU issue 820-2915 (youtube.com)
    • mon2
      • Dec 2019
      • 14250
      Hi. We have the next higher up model from yours and met Seamark at Nepcon last October. Would you not have the manuals? The machine should have pre-loaded profiles. Suggest to reach out to their team (they are a very strong manufacturer and had a large booth at the fair with many pieces of equipment).
      Sharing a key contact name who can help you through the process.
      Joy Rong
      Sales Manager
      PS: Plan B is for us to take pics of our profile temps, etc. but concerned if the heaters are the same on our model vs. yours.
      PS # 2 - Be sure to send our hello to Joy from Canada (she will / should remember our visit
      Hope this helps.
      • shahnld
        • Nov 2019
        • 159
        • Netherlands
        hi
        would really appreciate sharing pics of profiles. wel.i have seen 3 models and this one i got is a bit used one. not much of difference in heaters..since i also looked at the wds-620. fairly identical all these machines. same IR heaters, upper lower hotair..only design and some functions maybe different but heating method is 99%the same.
        see heaters..
        Cheers
        • mon2
          • Dec 2019
          • 14250
          Sorry - ran out of time today. Will do this tomorrow. Btw do you have a manual for this machine?
          • shahnld
            • Nov 2019
            • 159
            • Netherlands
            No problem. No i do not have manual since i got it used. but the man did sent me a link where the manual is. according to the manual these profiles does not melted lead free balls under gpu.
            Last edited by Lisa Su; 01-26-2024, 06:20 AM. Reason: Attached external file to the post
            • mon2
              • Dec 2019
              • 14250
              Here you go.
              • shahnld
                • Nov 2019
                • 159
                • Netherlands
                Here you go.
                Which nozzle you have on top..? with mesh or plan one large hole..? i ask this because the profile i used is much more higher than yours yet i did not get the balls melted.. the nozzle i got with it are not mesh but 1 large hole..
                i have IR at 220C constant.
                uper starts from 160 with 3C/sec. for 60sec. then 195 35 sec. then 225 35 sec, 250 30sec, 280 30 sec. 310, 325, for 35 sec. botton air temps are the same with 10C lower on every step.
                Real temp via external K thermocouple says 245-250 at the end of profile but chip is half melted while vrams around the chip are melted.
                Suggestion..?
                this nozzle it came with..
                • shahnld
                  • Nov 2019
                  • 159
                  • Netherlands
                  btw. i also have a firmware update received for it. not yet updated but seamark did send it..
                  • shahnld
                    • Nov 2019
                    • 159
                    • Netherlands
                    And does that mounting position means..?
                    • mon2
                      • Dec 2019
                      • 14250
                      We have the same open face nozzle - have the full kit of nozzles we purchased with the machine. We also have a HD side view camera to allow us to inspect the BGA balls in action and can definitely see the balls turn into a 'pillow' shape which then will activate the machine to suck up the part for the 'remove' profile or causes the BGA device to sink into alignment for the 'solder' profile. The machine is a dream to remove / solder on BGA - bit of a pain for the auto mount process but we need to invest more quality time in experimenting.
                      I would suggest for you to validate if the heaters / temps are as they should be - found this similar fault with our heller 1809EXL oven and the in the end, the thermister A/D board was defective. The board reported that the temps were met but the solder paste in the oven did not melt. We had to replace the temp board which was a fancy multiport analog switch that would allow for the X # of thermocouples to be sampled one at a time but as noted, the readings were in error yet reported that the solder will melt.
                      Do you have a socket for a thermocouple (K type I believe) ? But if the same board is common to the machine, the same fault will be observed with the external K couple unit. Validate the temp with an IR thermometer gun from your local hardware store. That is what we used to reach our conclusion. I recall also using yet another multimeter with a temp thermocouple to confirm once again that the temps were truly out of whack. Factory should be able to also offer you a replacement board (if required).
                      Q: If you take some leaded solder and place it under the hot air - does it melt? Start with this simple test using leaded low temp solder.
                      • shahnld
                        • Nov 2019
                        • 159
                        • Netherlands
                        Wel..as i said before. it does melt the leadfree vram chips while trying to melt the gpu.
                        since i did perform 2x rtx 3080 chips with this station and i do have a 4k camera pointed under the chip looking at the solder balls.. both reballs went ok. tested and cards are working fine.
                        only problem i am having removing lead free soldered gpu chips .
                        Your profile...? used for which boards..? laptop, tv or mobiles..?
                        gpu's are 8 layers pcb's. and solder melts 240C plus.. so that profile you sent is not meant for gpu boards..?
                        i just tested once again. 280C then ramp to 320 top at last 40 sec and the gpu chip did came lose. but i also increased top airflow from 5 to 8 this time. maybe i was using it too low.
                        i think i need to use high temp profile because gpu chips are thick and large compared to laptop cpu, pch or gpu.
                        Thoughts....??
                        A note.. Q: IR is set to 200.. but when i place thermocouple on it directly its beyond 400C. Is it how it is..? where is its own thermocouple located..? or placing thermocouple directly to it is just wrong..?
                        • mon2
                          • Dec 2019
                          • 14250
                          • shahnld
                            • Nov 2019
                            • 159
                            • Netherlands
                            Got it. that profile is ok for that board. I think the machine itself is ok. only i were using temps meant for small chips. that gpu for macbook is way too thin compared to a desktop 3080 chipsets.
                            His machine is a bit different than mine.. maybe higher or lower model.. but pretty much the same heaters and so on. even the new zm-r7220 is using the same principle all i can see is different design.
                            Anyway. thanks for your help. i will go with trial and error on donors boards until i reach what i need.
                            Btw. is that IR temps issue..? does it goes to 400 while you set it to 200? or placing thermocouple directly to it is wrong..
                            • decent1984.as
                              • Mar 2018
                              • 5
                              • england
                              Hi i have ZM-R6200 and i used to use it few years ago then stored it in workshop. Now im trying to setup but i cannot find the socket where this cable plug into machine or it has some external adapter which im missing?
                              • shahnld
                                • Nov 2019
                                • 159
                                • Netherlands
                                Hi..
                                Its for the screen. Its a. Video wire attached to the split camera..
                                • decent1984.as
                                  • Mar 2018
                                  • 5
                                  • england
                                  I have screen attached to barrel connector and camera has BNC connector. But this extra cable seems to be a kattle lead. I will check it
                                  • shahnld
                                    wds-580 rework station issue
                                    by shahnld
                                    Good day.
                                    i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                                    Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                                    kind regards...
                                    03-28-2024, 01:14 PM
                                  • minimania
                                    Need Schematic for jbc am6800 rework station
                                    by minimania
                                    hi all im looking for a Schematic for jbc am6800 rework station
                                    mine has stopped working fully
                                    it started with turning off when switched on then after a few off and ons it worked sort of for awhile
                                    now it wont turn on at all...
                                    01-28-2025, 03:44 PM
                                  • Peter_1402
                                    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                    by Peter_1402
                                    Hi Everyone,
                                    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                    1. Soldering iron works great
                                    2. There is a burnt mark on the hot air gun handle.
                                    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                    Reed switch tested ok with a magnet.
                                    From the above test, I can conclude...
                                    07-12-2025, 11:50 AM
                                    HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                    This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    09-12-2024, 02:20 PM
                                    MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                    This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 05:20 AM
