Capacitor wizard how to?
  • Beowulf
    • Dec 2012
    • 175
    Is anyone familiar with this meter that could help me understand how is it used for testing transistors, diodes and shorts on the PCB?
    These are some of the extra uses that are described in the user's manual but without much detail that a beginner like me could understand.
    thanks!
  • smason
    • 1652
    Re: Capacitor wizard how to?
    Simply put, it just measures really low resistance. I used mine back in '94 or so to find 2 broken lines on a rear window defroster. These were hairline cracks that I couldn't see.
    Because parallel tracks were fine, the whole thing reads like a dead short unless you can measure really low ohms. I forget how low the reading were. I basically ran the probes about an inch apart and slid them along the track until I saw the reading change.
    To find something like a shorted cap on a circuit board, you'd measure various points and theoretically as you get closer to the short the resistance will be lower.
    • Beowulf
      • Dec 2012
      • 175
      Thank you Smason.
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
