Atlas DCA55 Semiconductor Analyser
  • bbjunkie
    • Dec 2011
    • 301
    Took delivery of this today, not had much time to play around with it yet. Had a MOSFET I was sure had gone to transistor heaven, plugged the analyser onto it and it turns out it's fine.
    Not only did it save me the cost of a new device, but it has saved me who knows how long waiting for the replacement to arrive.
    Certainly seems like it will be a handy piece of kit, doubt it will get as much use as my Atlas ESR-70 though!
    Jim
  • AllElectronicsRepairs
    Wat is this component?
    by AllElectronicsRepairs
    Hi Everyone!
    The SMD code is AB5IB. It's a SOT-23 component (or similar).
    I tried to decode this component on every site I could find (SMD Code Book, etc.) with no success.
    Does anybody know what this component is? I have 2 of them on the board, and both give the same readings. I used DMM, as well as PEAK Atlas DCA75 Pro Advanced Semiconductor Component Analyser.
    Atlas says that NO COMPONENT IS DETECTED (both of them). Usually, it can detect ALL types of transistors, including Darlingtons, MOSFET, BJT, JFET, etc., Volt Regs, Diodes, etc. If...
    11-10-2022, 07:55 PM
  • Stephan Mathers
    EDMI ATLAS MK10 Electronic Meter Discussion
    by Stephan Mathers
    Greetings, new guy here but always interested in the crazy universe of modding
    We just finished construction of around 25 vacation houses, all inside the same private area.
    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
    05-20-2025, 09:09 AM
  • GlennB1975
    DFI EL336 motherboard cpu fans run but reset light lit on pci analyser
    by GlennB1975
    Hi there.
    First of all thanks for having me. I’ve posted in the introduce yourself section a little bit about myself.
    I have recently purchased two faulty motherboards for a fruit machine that i have, these PC’s are getting very hard to find now with them getting older, so seeing as ive had a bit of experience with repairing Nintendo DS’s i thought id try my hand at PC repair too.
    The first motherboard(ive not looked at the second one in any detail yet) has an issue which it will start up, the CPU fans spin but it does not post to BIOS, I get a slight...
    03-07-2024, 09:10 AM
  • lapfix
    About Me Analyser
    by lapfix
    facing this issue and can't find what i miss
    installing python at win 20H2 with his 3 Python modules:
    colorama
    crccheck
    pltable
    All is ok but when i try to open me analyser it just make w cmd windows than quikly dissappear !
    What i must install too , vc_redist.x64 and VBA65-KB974945-x86-ENU are installed too ....
    11-26-2022, 03:14 AM
  • Hillybilly
    philips HTS3530/05 sound system Schematic
    by Hillybilly
    Hi I've been trying to test for a fault on a pcb code 40-S351OA-PWB1G and ha ving tested a certain component with multimeter and atlas dca55 which came up with faulty component also the multimeter set to a diode mode couldn't get a reading.on board i'ts zd501,could anyone tell me if this component would make the pcb drop 42v which supplies to amp side of philips HTS3530/05 sound system please.A schematic with codes for parts would be much appreciated.Thanks
    07-24-2023, 08:13 AM
