issue while soldering plz help.
  • Jtroutt19
    • Aug 2011
    • 164
    maybe im doing something wrong....but on some of my holes i am having problems with the solder not flowing into the holes around the pin of the new cap. just wants to pool up on the board. Its really starting to frustrate me any suggestions. Using a butane soldering iron whith chisel tip.
  • mariushm
    • May 2011
    • 3799
    Re: issue while soldering plz help.
    You may have poor quality solder wire that doesn't have flux inside at all or maybe it's doesn't have flux throughout it's length (some no-name Chinese solder wire has very little flux inside and in irregular density).
    You need some flux to cover the surfaces you want to solder so that there's no microscopic layer of oxide preventing solder from chemically binding with the metal.
    Another possible reason for not getting a nice solder is too hot solder chisel/gun - if this is the case the flux may evaporate too fast and leave you with just the solder that goes nicely in a ball and sticks above the oxide layer.
    And last... you probably know this but if you're using a soldering gun, don't hold the solder on the tip of the tool - warm the metal ring on the board and the wire of the capacitor with the solder tip and touch the two with the solder wire from the opposite side.
    Here's some good tutorial about soldering. The second part shows the best examples:
    part 1: http://www.youtube.com/watch?v=J5Sb2...layer_embedded (at around 9 minutes in he explains about flux and various types of solder)
    part 2: http://www.youtube.com/watch?v=fYz5n...layer_embedded (see esp. at about 2-3 minutes in)
    part 3: http://www.youtube.com/watch?v=b9FC9...layer_embedded (a bit of specialty soldering - smd and chips with lots of pins)
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
      Multifix 425-01 and 450-01 Rework Flux Datasheet
      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
      - No Clean Formulations
      - Low residue
      - Range of activity to deal with different component solderability
      - Halide free
      - Suitable for dispensing
      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
      Both products are supplied in syringes or cartridges for application by dispensing....
      10-07-2024, 06:02 AM
    • evilkitty
      Flux causing high resistance short?
      by evilkitty
      Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
      Temp is on the left humidity is on the right
      i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
      The pin out looking down from the top is (note this is common cathode)...
      07-17-2024, 09:38 AM
    • novice1
      Acer Aspire E5-574G - Not Powering On
      by novice1
      Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
      This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
      To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
      11-03-2023, 05:53 PM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
