Found another DIY ESR Meter...Anyone seen this one?
  • TheLaw
    • Jan 2011
    • 477
    I'm on an ESR craze. Today, after about an hour of searching, I found this ESR meter, and it seems to be one of the better ones out there. You'll need to make your own PCB but that shouldn't be too terribly hard.
    http://kaspars.id.lv/?menu_id=32
    What do you guys think?
  • jeff58
    • Jan 2011
    • 14
    Re: Found another DIY ESR Meter...Anyone seen this one?
    I'm in the process of building one since I have most of the parts lying around except for the MCU. I have flashed an attiny before with Ponyprog and its a breeze. For Pic's, this will be my first and wondering is there anything I miss?
    The source code is in .hex that I know, what's with the .jal and the JAL compiler? Can someone enlightened me on these?
    I'll come to the calibration part later. Thanks
    • Ritalin
      • Sep 2010
      • 194
      Ya, I'd love to build one of these, and my father said he has a majority of the parts, the hard part would be programming the chips.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        I got a programmer that supports around 35000 chips and would love to help, problem is I live in Norway hehe.
        • Ritalin
          • Sep 2010
          • 194
          Well then we'd have to get you to buy the chips, program them, and do a big batch order.... OR.... You can just move to the US :P
          • frako
            • Jan 2011
            • 17
            .hex is the file you flash to mcu. .jal is the source code written in JAL language (a bit unusual choice to use that instead of C or asm). http://www.voti.nl/jal/index.html
            • Gabriel
              • Jan 2010
              • 620
              • Norway
              Maybe I will try to build this myself too or a meter that can read farad as well.
              If you need chips programmed I can do it, I think I got soic adapter as well if you choose not to use the dip.
              I can move to the US alright, just send me your sisters email and I will take it from there hehe
              • jeff58
                • Jan 2011
                • 14
                Post a question.
                Here are 2 PIC's with the same marking except for the ending code. Of cause the circuit indicated item 1. What's the difference between these two? Cost wise, the later is 34% cheaper.
                1. PIC16F690-I/P
                2. PIC16F690-E/P
                • Radio Fox
                  • Jan 2010
                  • 281
                  Post a question.
                  1. PIC16F690-I/P
                  2. PIC16F690-E/P
                  The "I" suffix means Industrial, with a temperature range of -40°C to +85°C.
                  The "E" suffix means Extended, with a temperature range of -40°C to +125°C.
                  The "P" suffix is the package type = PDIP (Plastic Dual-In-line Package).
                  ________________________________________________
                  Invisible airwaves crackle with life
                  Bright antennae bristle with the energy
                  • jeff58
                    • Jan 2011
                    • 14
                    Thanks Radio Fox.
                    So if its just the temperature ratings, I can go for the cheaper one since it won't be nearing to these operating temperatures, right?
                    • Radio Fox
                      • Jan 2010
                      • 281
                      Thanks Radio Fox.
                      Yep. Buy whichever one is the cheapest.
                      • jeff58
                        • Jan 2011
                        • 14
                        Thanks a lot!
                        • TheLaw
                          • Jan 2011
                          • 477
                          Hehe. I forgot about this for a while. In the (huge) process of building an amp+ speakers. When I finish that, I think I'll try one of these.
                          • B2L_Repairs
                            Huawei D15 no power found corrosion damage
                            by B2L_Repairs
                            I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
                            02-06-2025, 01:05 PM
                          • Grouickman
                            Hofmann geodyna 6300 Wheel balancer
                            by Grouickman
                            Hi there,
                            First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                            Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                            I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                            I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                            03-31-2025, 05:29 AM
                          • gagarasta
                            Operating system not found, cannot enter bios or boot to usb
                            by gagarasta
                            Hello everyone, I had issues on my laptop acer 4752G
                            I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
                            1. On system information its uefi not bios/legacy
                            2. Advanced restart but there's no uefi setting
                            3. Try to reinstall my pc using fdd but cannot enter boot selection
                            4. Press f2 f8 f10 only beep but straight into boot
                            5. Try reflash bios using fdd fn key+esc+power not success
                            6. Take the cmos battery off and...
                            11-05-2023, 11:23 AM
                          • dropfry
                            Dead t480s, trying to troubleshoot. May have found something.
                            by dropfry
                            Hello. I have a lenovo that will not show any indication of life. No led, sound or anything really. So I took the motherboard out and started testing points according to the advice in this thread: https://www.badcaps.net/forum/showthread.php?t=102409
                            PU201 is Showing 6v
                            VREG3/5 show a high value (around 20v) for a split second then drop down very quickly. Hold around 1v but then continue to drop to zero. One is showing .2v.
                            Fuse PF1 is showing very low voltage (which according to the thread deals with docking and is expected)
                            09-29-2023, 02:38 AM
                          • nassimhamdi
                            Acer aspire V5-591 electronic component not found!
                            by nassimhamdi
                            hello
                            today i have laptop Acer aspire V5-591 DA0ZRYMB8G0 REV: G MODEL: ZRY
                            the problem of this notbook is powering on but black screen, when i verifing the motherboard i found TWO electronic component not found! AS PICTURES BELOW please help
                            ,thanks ADVANCED....
                            08-04-2023, 01:20 PM
