Legion 5 15IMH05 Bios
  • khaly
    • Jan 2015
    • 22
    • Romania
    Windows update downloaded a few updates , among them was a firmware update.It restarted normally ,but after the restart all I can see is a blinking white line in the top left corner , then the screen goes black and nothing happens.
    I cannot enter bios ,the boot menu doesn't work either and the same goes for the Novo button.
    I need a bios dump or somebody that can help me rebuild the original bios dump.
    Thank you.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
    Re: Legion 5 15IMH05 Bios
    Try:
    Become a Badcaps supporter
    Thanks to all supporters.โ€‹
      • 22157
      Dmi 532000 - 533fff
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
        Originally posted by SMDFlea
        Dmi 532000 - 533fff
        • khaly
          • Jan 2015
          • 22
          • Romania
          Hello again and thank you.The notebook boots up now but there is a problem with the display and it looks like this .It looks the same in bios , dos or windows.I still think there is something messed up in the BIOS , any help is apreciated.
          I cannot update the BIOS since now it has the latest version.
          Thank you again.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
            I doubt the bios is the reason, because it is extracted from the bios update (EFCN50WW) at the Lenovo site.
            Thank you again.
            It was PITA to find previous version, but somehow managed to find EFCN45WW, I've attached below the file, Dmi & ME are OK, so you can test it, and afterward update to the EFCN50WW if you want. Reply with the results, fingers crossed, good luck.
              • 22157
              To find previous versions edit this : https://download.lenovo.com/consumer...s/efcn50ww.exe
              Edit efcn50ww to efcn49ww ,48,47,46,45 keep going back one version until it downloads one.The method works with all lenovo updates to find previous versions (if they`re available)
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
                I know this method and it was the first thing I did, but all previous versions have been removed. None of the previous versions are available on their server. Everything is removed.
                Edit: Oops, I've somehow missed 48, still (the only one left) available
                Edit2: Will prepare (48) bios file for testing...
                Edit3: Done. Here it is ready for programming:
                • khaly
                  • Jan 2015
                  • 22
                  • Romania
                  Guys , thank you again.I have some more "interesting" news.I programmed both bios files that Vesko356 posted and ended up with the same result , crap image.
                  I noticed the Nvidia video driver has a code 43.It's not a windows or a driver problem as it worked before this update fiasco and I reinstalled windows 10(latest version from the microsoft site) just for the lol.
                  After I programmed the bios with the 48 version , I entered the bios and I saw the option.I switched from the discrete to dynamic and the image was perfect.I restarded the notebook , got into windows ,installed the intel driver , the nvidia was still giving the code 43.
                  I decided to update the bios from 48 to 50 and see if something happens and it did.The display was crap again and the option to change from discrete to dynamic is gone.I enabled the option to back flash (very hard to do when you can't see sh*t) and downgraded to version 48 , but the option didn't appear .I have to reprogramm the bios with the file from Vesko356 .
                  I still think it's a problem with the bios file.You helped me a lot , thank you so much.
                  • 4everbacon
                    • Oct 2021
                    • 2
                    • Ukraine
                    Hello! Can anyone please upload 52 bios *.bin file, because my legion can't boot up, so I can't extract this file.
                    • shiran
                      • Feb 2021
                      • 5
                      • sir lanka
                      Acer TravelMate P215-51 (TMP215-51) Bios LE5FB REV 2.1 [bios please]
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12423
                        No no no. This is topic for Legion 5. Use search function or create new topic for your case.
                        โ†ต
                        โ€‹https://www.badcaps.net/donate
                        • Jeroentje
                          • Dec 2017
                          • 82
                          • Nederland
                          Dmi 532000 - 533fff (added on file)
                          Is there a tutorial about adding or edit the DMI ?
                          based on the comments assume you can't clone a working bios over a corrupt one ? (with programmer )
                          thanks in advance.
                          • Sergio06
                            • Mar 2023
                            • 16
                            • Brasil
                            Corrupted Legion 5-15IMH05H BIOS (HELP)
                            can someone help me with my legion 5i?
                            I went to update the BIOS and apparently everything went well. but when legion restarted it never gave the screen again. It just keeps blinking. ie corrupted the BIOS.
                            I'll leave a copy I made with ch341 of the faulty BIOS.
                            Serial Number:PE07PV5N
                            Machine Type Model:82CF0004BR
                            Legion 5-15IMH05H
                            here is the latest version available for it: https://pcsupport.lenovo.com/us/en/p...me=BIOS%2FUEFI
                            • peste
                              • Dec 2016
                              • 13793
                              • ROMANIA
                              Re: Corrupted Legion 5-15IMH05H BIOS (HELP)
                              Legion 5-15IMH05H
                              try post #2
                              https://www.badcaps.net/forum/showth...ght=5-15IMH05H
                              • Marc97
                                • Jan 2016
                                • 189
                                • Phillipines
                                Virgin bios file from Lenovo, it doesn't contain any DMI because you didn't upload your backup file.
                                HI can you help us also,,, legion 5 pro 16ACH6H SN NUMBER PF3BXNSM
                                Last edited by Vesko356; 06-01-2023, 11:52 PM. Reason: Bios removed ,thread hijack.
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria ๐Ÿ‡ง๐Ÿ‡ฌ
                                  Read the rules before posting, do NOT hijack threads:
                                  • Marc97
                                    • Jan 2016
                                    • 189
                                    • Phillipines
                                    sorry
                                    ... i have just read common reply by hardware1 to someone which maybe same as my board number,,
                                    • peste
                                      • Dec 2016
                                      • 13793
                                      • ROMANIA
                                      sorry
                                      read the post above...next time search before posting the bios on the site, you might find what you need...if it doesn't work post in the same thread..always post the corrupted bios too..
                                      • koby058
                                        • Jan 2017
                                        • 387
                                        • israel
                                        Hi Gentlemens,
                                        please help with bios for this Legion 5 15IMH05H
                                        original attached
                                        S/N: PF2BZGEb
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • macabook
                                          ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
                                          by macabook
                                          Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
                                          ๐Ÿงฉ Initial Issue
                                          07-24-2025, 02:17 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                          Lenovo Legion 7 15IMH05 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion 7 15IMH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7 15IMH05 boardview and 7 15IMH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 04:30 AM
                                        • cr4zychriss
                                          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                          by cr4zychriss
                                          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                          • Barebone / Chassis: TongFang GK7MRFR
                                          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
