need bios dell precision 5520 la331p
Tags: None
Every donation made will go towards server fees and maintenance costs. -
Re: need bios dell precision 5520 la331p
here is itAttached Filesif you find these attachements useful please consider making a small donation to the site
Here (Same Version 1.21.0):Attached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
please remove the passwordAttached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Greetings please help me clean the region of my bios since it does not start fast and I want to change the serial number for anotherAttached Filesif you find these attachements useful please consider making a small donation to the site
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
precision 5520 service tag change request
Hello
I got a dell Precision 5520 for repair somebody worked on it before me and changed the bios file now the service tag that is written on the back of the laptop is different from what is shown in the bios setup menu
I already get the warning Alert! TPM module is not detected too
can anyone make a correct Bios dump file for me please?
The service tag written under the device is 1KVV0N2
Thank youComment
ORG Work But It Has a PasswordAttached Filesif you find these attachements useful please consider making a small donation to the site
Try again me be the orig file from Vesko356 as me clean file helps ...
The files from Vesko356 are always great.Attached Filesif you find these attachements useful please consider making a small donation to the site
hello
Can you fix my BIOS file? ON the Dell_Precision_5520_vesko356_unlock_outimage.zip , the laptop works but it takes a long time to turn on. On the original it starts without the image. ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
Channel: BIOS & Schematic Requests!
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by MMH3Hello,
i would appreciate, if someone could help me.
DELL: 3450 sff
Servicetag: (!) obviously FAKE - ABC2345
Mainboard: 0GK35Y - serial /ABC2345/CNFCW0023800L6/
Chipset: Intel W580 (Rocket Lake PCH-H)
BIOS: 1.34.1
ME: 15.0.50.2633
mor data can be found the HW-Info-data in the rar-file
I have this BIOS from a DELL Precision 3450 SmallFormFactor mainboard i bought refurbished.. from china.
The board itself works without any issues.
My goal was to clean the ME of this and fully...-
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
Channel: BIOS Requests ONLY!
- Loading...
- No more items.
