Sceptre X22WG Gamer - Fixed
  • Radio Fox
    • Jan 2010
    • 281
    Aquired this moniter a couple of days ago. It was sold as "unit powers up but no display". From the description I thought it might have been a PSU capacitor problem.
    On plugging it in, the power LED flashes blue, indicating no input signal. It also displays some kind of calibration/setup screens (colour bars, greyscale bars, blue, red green screens etc.) continuously. The only way to stop it was to unplug it from the mains.
    I opened it up to check for bad caps anyway, but it looked OK. I suspected a corrupted EEPROM. Googling the number on the control board turned up nothing. I wondered if there was some kind of service menu that I could access. I jotted down the different combinations of button presses using the buttins on the side of the monitor. There are 5 buttons on the side, so that made 31 combinations.
    I finally found the combination of "Vol", "Source", & "Auto" brought up a DEBUG message. Pressing the "Menu" button brought up the "burn in" menu which was set to "ON". I used the + (or -) button to turn it off. Pressed "exit" (Auto button). Pressed "Auto" button again & the screen displayed "No signal" for a few seconds, before going into standby. Yipee.
    Not bad for a total price of £11.50, plus a lot of button pushing!
    Thought I would post this as I couldn't find anyone on the net with a solution.
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sceptre X22WG Gamer - Fixed
    Good job!!!
    PlainBill
    • EGuevarae
      • Nov 2008
      • 1336
      Nice. I had a Planar 19" with a similar problem and it had a similar fix. This sort of things are not widely documented.
      Good price for a 22" unit..... congrats ...
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • Radio Fox
        • Jan 2010
        • 281
        Yep. I couldn't find any service manuals on line for this monitor, so I just poked around, hoping it had some kind of engineer/service menu. Luckily, it did.
        I do wonder how it got into burn-in mode in the first place though. Must have just been a glitch.
        There are widespread reports about the DVI input going faulty on these monitors after a while. Unfortunately I cannot test it, as my PC doesn't have DVI output.
        btw...it also came with mains lead, DMI lead, & printed manual.
          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-07-2024, 05:00 AM
        • howardc64
          Fixed Sceptre U435CV-U Another bad cap from poor cooling
          by howardc64
          39uF 160V cap bulging (see pic). Replaced (temporarily with one thats too tall for the space) and fixed.
          But root problem is once again high heat density (18mm between board and back cover). Combined single board main+PSU and no fan.
          While shopping for Nichicon replacement, all 10k hr @ 105C was 17.5mm height which barely clears the rear case. Failed cap was 13mm tall with much fewer choices.
          Seeing so many newer TVs die by heat (BGAs etc) Need to figure out an easy way to mount fans ...
          08-05-2022, 11:03 AM
        • howardc64
          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
          by howardc64
          TV was fixed just after removing Samsung's rear snap cover.
          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
          Maybe PSU->backlight connector didn't have a good contact?...
          07-23-2025, 12:34 AM
        • spirittoo
          Sceptre 48" TV backlight LED`s
          by spirittoo
          Trying to fix a backlight problem with a Sceptre 48" TV.
          I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
          So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
          Anyone know how I can remove those leds without damaging them?
          11-11-2023, 10:23 AM
        • tom_h
          Sceptre X505BV, blue LED, no display
          by tom_h
          Hello all,
          I have a Sceptre X505BV-FMDR8HJ1PE8 tv that had been gradually over time taking longer
          and longer to come on, now it will no longer display any image. Original symptoms
          are the red standby LED would turn to blue immediately when pressing the power on
          button, but there would be a delay for the "SCEPTRE" image to appear on the screen
          and backlight to come on. The delay kept getting longer, then it would go from blue
          LED back to red. Then when I pressed the power on button again it would bring the
          display up and work fine....
          10-05-2023, 06:53 PM
