Ba41-02243a bios dump
  • Guilty_2121
    • Jan 2021
    • 43
    • Türkiye
    hello everyone i'm a home user and i need my samsung np270e5e-x06tr (Ba41-02243a) bios dump.
  • peste
    • Dec 2016
    • 13599
    • ROMANIA
    Re: Ba41-02243a bios dump
    post the backup of the bios
    • Guilty_2121
      • Jan 2021
      • 43
      • Türkiye
      backup bios -intel cpu and nvidia gpu
        • 21922
        The backup is incomplete or corrupt. What programmer are you using, have you desoldered the chip or are you using a clip .
        • peste
          • Dec 2016
          • 13599
          • ROMANIA
          the bios must be 8MB, use the HxD program, make more copies and comparisons, which of them look like posted here.
          • Guilty_2121
            • Jan 2021
            • 43
            • Türkiye
            I'm a home user and i only have ch341a and desolder bios chip. It's a winbond 25q64cvsiq.
            I try to read it with ch341a promram versions and they didn't read the chip so i tried colibri program. That's what i get.
            I try the bios in this thread (2nd bios). Same problem 1 second fan spins and led blink thats it.
            https://www.badcaps.net/forum/showth...ghlight=np270e
              • 21922
              make sure the chip is soldered or inserted into your adapter ok. Try NeoProgrammer,and AsProgrammer software , if all backups are the same then the chip is bad .
              EDIT: Post your backups from both tries
              https://www.badcaps.net/forum/showpo...04&postcount=7
              https://www.badcaps.net/forum/showpo...6&postcount=10
              • Guilty_2121
                • Jan 2021
                • 43
                • Türkiye
                I think this time i made it correct with neo and as. they both 8mb. thank you for neoprogrammer and asprogrammer.
                  • 21922
                  The backup is ok. Whats the history of the laptop as the model number and bios version don`t match,it might have been flashed with the wrong one.
                  Can you double check that the board number is Ba41-02243a
                  EDIT: Try this bios - https://www.badcaps.net/forum/showpo...15&postcount=9
                  • Guilty_2121
                    • Jan 2021
                    • 43
                    • Türkiye
                    my motherboard is Ba41-02243a and on the other side is says lampard_n14x rev 1.0.
                    I'm sure my laptop is samsung np270 but rest of the number is deleted in times. I found a paper on my hdd and it says np270e5e-x06tr.
                    History is my little brother hit it with a ball and it fall from the table. Screen broken, after take the screen off. i tried to use with a montitor and it was just start for 1 seceond fans spins, light blinks and that it.
                    After that bios my motherboard is not responding and have a green light on charging(there is no battery) but it's so weak.
                    and i don't have 5v in usbs anymore. i think i should go back to my bios ?
                      • 21922
                      Its up to you if you want to try the other bios .The history of the laptop would have been helpful in your other thread .
                      • Guilty_2121
                        • Jan 2021
                        • 43
                        • Türkiye
                        ok thank you so much. I think i have a problem on my 5v power rail because this time i have 2v on usbs. if i can find it i can do something.
                        Thanks for help master.
                        • mkdj
                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                          by mkdj
                          Dear all,
                          I have a ASUS ZenBook UX480F with the following symptoms:
                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                          10-19-2025, 04:41 AM
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Citymin
                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                          by Citymin
                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                          The charging red LED lights up, but the charging screen doesn't show any indication.
                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                          (I've tried removing the battery and resetting the device, but the issue persists.)
                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • DynaxSC
                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                          by DynaxSC
                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                          11-17-2023, 10:56 AM
