Asus x550jx_rev2.0_dimm0_disabled
  • naseee
    • Nov 2016
    • 104
    • india
    Here ram disabled in bios
    i don't know it's working or not
    downloaded from internet
    worth a try
  • pirati
    by pirati
    10-27-2025, 04:20 PM
  • DynaxSC
    Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
    by DynaxSC
    I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
    The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
    Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
    Usually on ASUS boards it worked...
    06-14-2024, 03:49 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • oragano
    ASUS ex-b250-V7 motherboard bios corrupted - by me
    by oragano
    hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
    So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
    i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
    10-17-2024, 02:53 AM
  • chudofermer
    Asus Ally rc71l bios
    by chudofermer
    Hello!
    Received Asus Ally rc71l with the wrong bios.
    Have the original package and all serial numbers.
    Can anyone help me understand what is wrong?
    Condition:
    Received with an original box with all serial numbers
    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
    Got the flash dump, nothing found on DMI section
    No Windows key, just key ID on the box
    What is done:
    1. Flash the latest bios version with serial numbers...
    03-05-2025, 05:42 AM
