please patch this ThinkPad S1 Yoga 12
  • rachidell
    • Aug 2016
    • 140
    • algeria
    Hi i have lenovo yoga12 motherboard ZIPS3 LA-A342P REV 1.0 with bios pass
    anybody have this dump please
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: Bios yoga12
    Post your Bios dump .
    • rachidell
      • Aug 2016
      • 140
      • algeria
      Re: Bios yoga12
      Sorry for the delay
      Thanks in advance
      • rachidell
        • Aug 2016
        • 140
        • algeria
        Re: Bios yoga12
        hiiiiiiii
        • marcin02152
          • Oct 2014
          • 134
          • Polska
          Re: Bios yoga12
          Sorry for the delay
          Thanks in advance
          This dump working and no password. Thanks.
          • Ahmedshady
            • Feb 2018
            • 9
            • Egypt
            Re: Bios yoga12
            Thank you man
            • omruu9
              • Apr 2016
              • 70
              Please help to patch this file for lenovo yoga 12 there no lenovo translation services etc to patch any friend can help thanks in advance
                • 22012
                Re: please patch this ThinkPad S1 Yoga 12
                The patcher will only work if the IO/KBC is an MEC chip !!
                  • 22012
                  The S1 Yoga 12 has 2 bios chips.
                  • omruu9
                    • Apr 2016
                    • 70
                    yes but second one is 8mb & its not uefi image
                      • 22012
                      motherboard part number ?
                      • omruu9
                        • Apr 2016
                        • 70
                        Zips3 la-a342p rev : 1.0 2014-11-12
                          • 22012
                          The 8MB chip has the flash descriptor and ME region. If the 2 chips are joined together with a hex editor then UEFITool will report the bios as a UEFI image.
                          Post the 8MB backup .
                          • omruu9
                            • Apr 2016
                            • 70
                            here is 8mb file dear
                            • omruu9
                              • Apr 2016
                              • 70
                              did you patched dear ...?
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1356
                                • France
                                hi,
                                NEED CLEAN EC (Password )
                                SER#
                                B0 SB20F65736C1KS5AGG3Y4
                                C0 S20DKS0A900MP10CSPN
                                First time for me with that
                                read with RT809F with adapter Kb9012
                                I hope reading will be good.
                                Isn't it easier to do that?
                                Veritanov or via keyboard cable on rt809f or isp
                                I still have trouble with these tools.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1356
                                  • France
                                  while looking, I found this
                                  It's OK now
                                  just need reprogram serial and others with LENOVO diskette
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1356
                                    • France
                                    I still have a problem, I can not put uuid and rfid.
                                    must modify the bios and put clear these bits to be able to rewrite ??
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1356
                                      • France
                                      Edit: SOLUTION FIND
                                      DON'T USE FILE WITH PDF
                                      JUST REPLACE 0x200 to 022F on your original EC Dump
                                      no lost UUID ,serial and others numbers
                                      • okbalord
                                        • Jun 2017
                                        • 205
                                        • Algeria
                                        Re: Bios yoga12
                                        Sorry for the delay
                                        Thanks in advance
                                        work fine ty
                                        OKBALORD
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                          Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 04:10 AM
                                        • Loki_Fido
                                          Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
                                          by Loki_Fido
                                          Hi everyone, hope everyone's having a great day.
                                          I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
                                          I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
                                          So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
                                          Does this mean the BIOS is fine? making it a hardware issue?
                                          I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
                                          03-14-2025, 07:42 PM
                                        • Maxpower3
                                          Brand name and Model Type for Lenovo error 2202 product name is invalid
                                          by Maxpower3
                                          Info for error 2202 LenovoThinkPad models and type
                                          Extract from ThinkPad Maintenance Utilities Configuration File
                                          plnsrv.ini Version 1.01
                                          Some information that may be useful
                                          There must also be missing models, add them to the list if you know of any.
                                          Code:
                                          brand name
                                          20B1=ThinkPad Edge E445
                                          20B2=ThinkPad Edge E545
                                          20BC=ThinkPad Edge E145
                                          20BM=ThinkPad X140e
                                          20BL=ThinkPad X140e
                                          20A3=ThinkPad X230s
                                          20AH=ThinkPad X230s
                                          20AK=ThinkPad X240s
                                          20AJ=ThinkPad X240s
                                          02-21-2024, 10:27 AM
