BIOS dump for 14-FP5-6L-GDDR5X2
  • b171331
    • Oct 2014
    • 15
    • SRB
    HP 14-cm1600na
  • dennison flores
    • Apr 2021
    • 22
    • Philippines
    Re: BIOS dump for 14-FP5-6L-GDDR5X2
    HP 14-cm1600na
    is it working????
    • peste
      • Dec 2016
      • 12786
      • ROMANIA
      Originally posted by dennison flores
      is it working????
      make a backup of your bios and try it..if it doesn't work post the full name and model of the laptop and the bios backup ..
      • jimore
        • Nov 2020
        • 177
        • mexico
        original bios
        • Cba_Notebook
          • Sep 2021
          • 3
          • Argentina
          Ok for HP hp 14-dk0736ms
          Thanks!!!
          • lonelybdy
            • Oct 2020
            • Turkey
            HP 14-cm1600na
            hp 14-cm1000nt amd onboard vga
            • suntech89@yahoo.com
              • Jan 2020
              • 8
              • Pakistan
              14-fp5-6l-gddr5x2
              continously running Fan
              Plz I need Help.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11732
                Originally posted by suntech89@yahoo.com
                14-fp5-6l-gddr5x2
                Plz I need Help.
                Your original corrupt bios file ? Your device's serial number ?
                • denilloo
                  • May 2013
                  • 60
                  • indonesia
                  Re: Need schematic or boardview for HP 14-cm0012ax
                  Try this
                  • ajbernasko
                    • Mar 2022
                    • 229
                    • ghana
                    I tried not okay, crashes and cannot load windows
                    • ajbernasko
                      • Mar 2022
                      • 229
                      • ghana
                      i HAVE ADDED MY BIOS IF NEED TO CHEC AND CORRECT FOR ME./ THANK YOU
                      • Jonatang
                        • Oct 2022
                        • Colombia
                        good morning, could you help me to correct this bios file, thanks
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11732
                          HP Notebook - 14-cm1025la
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11732
                            Serial : 5CG9295GNJ
                            • ajbernasko
                              • Mar 2022
                              • 229
                              • ghana
                              Serial : 5CG9295GNJ
                              Will work for AMD please ?
                                • 20873
                                14-cm1025la specification AMD Ryzen 5 3500U https://support.hp.com/uy-es/document/c06364908
                                • ajbernasko
                                  • Mar 2022
                                  • 229
                                  • ghana
                                  It still crashed, i think i have ryzen 3 instead of 5
                                  • ajbernasko
                                    • Mar 2022
                                    • 229
                                    • ghana
                                    hp notebook - 14-cm1025la
                                    serial : 5cg9295gnj
                                    crashed again
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11732
                                      crashed again
                                      Check your hardware, that's a virgin bios.
                                      • ajbernasko
                                        • Mar 2022
                                        • 229
                                        • ghana
                                        Okay, where should i check plss
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • cekcons
                                          g1 assassin Rev 1 bios dump - main and backup needed
                                          by cekcons
                                          main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                                          thanks
                                          01-23-2024, 03:26 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
